Engine Swap Resources Thread - Under Construction
Old Sep 10, 2008 | 09:24 AM
ceo.rowe's Avatar
ceo.rowe
3 Piece Suit
Default Clutch options for Tranny
This is my first post on HAN.
If you were swapping a B18B1 into an EG, but wanted to install a B16A/B16B Tranny, would you run the B18 Clutch or B16 Clutch?
Old Sep 13, 2008 | 12:29 AM
josuph1999's Avatar
josuph1999
Default h22 into 95 honda del sol
i have an 95 honda del sol and wanted to install an h22 motor were do i start?
Old Jul 20, 2009 | 02:38 PM
HONDAHATCHY's Avatar
HONDAHATCHY
So droppin a b18b1 in to a 95 vx is a direct swap no need to change out or modify the wire harness
Old Aug 25, 2009 | 06:44 AM
kenny8585's Avatar
kenny8585
UHmm, i see that b16a just bolt on for 5 th generation. Seen to be eazy to swap but not sure.
Old Mar 31, 2010 | 08:16 AM
daveytrackels's Avatar
daveytrackels
I don't really understand.. Can someone explain it to me?
Old Apr 26, 2010 | 02:58 PM
1998NACivic's Avatar
1998NACivic
Default Cheapest Motor Swap
I've have a 98 civic LX with no motor and was wondering what the other D-series options I have are that would bolt right in using the same everything like transmission and what not. For example would a D15B8 fit? I could understand changing the intake manifold so OBDII wouldn't be affected, but I am broke and need to get this running asap for as cheap as possible and was wondering what my options are so I can find a cheap motor and throw it in. Thanks in advance!
Old Mar 18, 2015 | 11:46 AM
EXChris401's Avatar
EXChris401
I'm new to the forum. I've got a ek, and the motor threw a rod. I'm in the process of removing the old egine. My host tranny I know is good. The donor motor I purchased came with a tranny and removed it from the donor motor. My question is can I pull the blown motor without pulling the transmission out of the car replace it with "newer" motor?
Last edited by EXChris401; Mar 18, 2015 at 11:47 AM. Reason: I wasn't finished, stupid phone
Old Mar 1, 2019 | 03:15 PM
Vito Ilari's Avatar
Vito Ilari
Default 93 delsole b18b swap
A friend of mine has a 93 delsole obd1 and hes trying to swap a b18b in it. Just wondering how the wiring would end up. Its a obd1 with the ecu and the b18b is a obd2. Wat harness do i need for this swap?
gabybabi01
Engine Swaps, Tech & Tuning
2
Apr 29, 2009 09:58 AM
EKgsr11
92+ Civic/EL & Del Sol
6
Jan 26, 2006 08:28 AM
eownzit
2
Nov 14, 2004 05:59 PM
dawrenn
10
Mar 2, 2004 08:48 AM
97civicCx
Feb 29, 2004 09:15 AM
