B18B1 swap into 6 gen. HB question...
So I looked through all posts and maybe I missed something, but I can't find anything about whether beside getting B18B1 engine, I need ECU, wiring harnes, exhaust or anything else. Can Someone verify that. I do understand that this is one of the easiest swaps, but please let me know what else I need before I start the swap.
Thanks
Dan
Thanks
Dan
Thanks
Dan
Thanks
Dan
You'll also need the complete normal swap kit. Axles, shift linkage, mounts (I'm not sure specifically which mounts though), the complete engine/sensor/tranny/manifolds combo and the proper ECU. I think for mounts you need the '99+ Si rear mount and a B-series front lower tranny mount and front lower engine mount. The other 2 can reuse your Civic pieces. Like I said, I haven't done my swap yet (probably another month or so, I'm planning to post each step as I do it) but this is what I've heard. Aside from the normal swap headaches (axle nuts, shift linkage pin ...) the swap is pretty easy.
I would definately recommend you purchase a Helm's manual for your car and also one for the car your engine comes from (IE a '97 Civic and a '98 Integra if that's what you get). Each book contains a 15 page or so section on how to remove and install and engine, with pictures, torque valves and any special tools you need. It's extremely helpful and will give you a good starting point on the mechanical aspect of it all. They're about $66 a piece shiped (at least a year or two ago) but worth their weight in gold.
http://www.helminc.com/helm/homepage.asp?r=
They're the factory service manuals used by OEM techs. Just call them up with your credit card and at least get your Civic's one. Good luck and let us know how it goes.
sir_crx
Engine Swaps, Tech & Tuning
36
Nov 15, 2002 08:50 AM
