NGK Iridium Spark Plugs
Old May 3, 2006 | 09:05 PM
JDMPONY00's Avatar
JDMPONY00
by the way i went to the site and didnt see ngk coppers? and i havent found them anywhere else? couldnt find just a bkr6e either they were all bkr6e#
Old May 3, 2006 | 10:10 PM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
NGK Irridium are pretty good. That's what I'm running right now.
Old May 3, 2006 | 10:20 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by JDMPONY00
so for my b16 what do you think would be the best gap and heat range, keep in mind im not boosted yet the turbos still in my room i have to save some more b/c i want bigger injectors and want to dump the emanage for a s200, so i would just be puttin plugs in N/a for the time being.
I would leave it at stock gap (.044") until you install the turbo.
You will want the BKR6ES-11 plug for your B16 at this point in time. I strongly recommend going one or two heat ranges colder when the time comes for turbo if you want to keep the spark plug unmelted.
Old May 4, 2006 | 03:58 AM
3rdgenlxi's Avatar
3rdgenlxi
I've got em in my ZC and they work better for me than stock ngk's. I used to get 250 mi per tank of gas and now it's up to 300. Not bad for just plugs and some fuel injector and t/b cleaner. Plus the maintainance interval is like 60,000 miles - you can't WISH to go that far on copper.
Old May 4, 2006 | 06:07 AM
JDMPONY00's Avatar
JDMPONY00
Thanks schmoo, this weekend im doing alittle mantinance.
Old May 4, 2006 | 06:13 AM
JDMPONY00's Avatar
JDMPONY00
one last thing then i will leave you alone schmoo haha, all the ngk's say the b16 gaps is at .052 so i need to gap them down to .044 right?
Old May 4, 2006 | 06:39 AM
Running925's Avatar
Running925
Your Powder Coater
i only ran Iridium's once due to the fact that i melted everything else with a big nitrous shot.
i run cold ngk's now.. BKR7E's (turbo/nitrous application)
if your stock.. use the oem NGK's
Old May 4, 2006 | 08:59 AM
Provocateur
On permanent hiatus
I have no idea. I would assume that the gap would be the same as my GSR at .044". If it says .052, do that. If you have misfiring problems, close the gaps down.
Old May 4, 2006 | 09:18 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
I use NGK BRK7E-11 for my lightly built B16A. I think they're the OEM plugs from the b18c5. I think most specialty plugs are just gimmicks. Rocket motorsports sells plugs that actually cause a dyno-documented couple hp, but at $40, I don't see the point. Aside from those, I haven't seen any evidence of gimmick plugs doing anything over OEM.
Old May 4, 2006 | 10:43 AM
3rdgenlxi's Avatar
3rdgenlxi
check out these plugs. They have the data to prove the increase in HP.
http://www.e3sparkplugs.com/
For a primer on spark plug technology:
http://www.e3sparkplugs.com/techoverview.asp
