NGK Iridium Spark Plugs
Old May 4, 2006 | 03:26 PM
JDMPONY00's Avatar
JDMPONY00
Originally Posted by Däs Schmoo
I have no idea. I would assume that the gap would be the same as my GSR at .044". If it says .052, do that. If you have misfiring problems, close the gaps down.
ya my my denso's are gapped to .044 so ill just look in my haynes book or somthing.
Old May 4, 2006 | 05:28 PM
JDMPONY00's Avatar
JDMPONY00
in the haynes book it says to use NGK PFR6L-13 at a .047-.055 gap those are the NGK LAser platinums?
Old May 4, 2006 | 06:05 PM
remy's Avatar
remy
OEM is NGK. Stick with those.
I had Denso plugs. They sucked.
I had Iridium plugs. They sucked.
NGK makes both iridium, platinum, regular etc.... !
so hows NGK OEM???im kinda of confused
Old May 4, 2006 | 06:38 PM
Wharbone's Avatar
Wharbone
Just get the NGK OEM's (copper). They are dirt cheap and work great.
Old May 4, 2006 | 07:38 PM
JDMPONY00's Avatar
JDMPONY00
The plugs they say that are oem for 99-00 civic si b16a2 motors in both my cars owner manual and my haynes book are the NGK PFR6L-13's which are NGK laser platinums. so im torn on what to do i think ill just get what the books recommend?
Old May 4, 2006 | 08:04 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Iridium plugs don't come OEM.
Old May 7, 2006 | 06:08 AM
remy's Avatar
remy
coool,thanks!!! ill be doing that then!!!
Old May 7, 2006 | 09:35 AM
JDMPONY00's Avatar
JDMPONY00
I just put the oem laser platinums in my b16 and its running great. They are more expensive but they will last longer than the coppers. But either way you can't go wrong coppers or the oem laser platinums. However, I was not pleased w/ my iridium plugs.
Old May 7, 2006 | 10:04 AM
thomas's Avatar
thomas
pew pew pew
oem ngk's unless u have nawsssss or turbo
