Civic is dying while driving
Old Sep 18, 2002 | 07:31 AM
  #31
Paul's Avatar
Paul
Eater of Rice
The ignitor and coil pack are inside the distributor, you need to take the cap and rotor off to access it.
Old Sep 18, 2002 | 09:35 AM
  #32
droopy1592's Avatar
droopy1592
thanks, I was looking for that
Old Sep 20, 2002 | 08:29 AM
  #33
4-banging's Avatar
4-banging
what about your alternator? ever checked that? disconnect the + and if your car turns off your alternator is bad....
Old Sep 20, 2002 | 12:13 PM
  #34
MoFo's Avatar
MoFo
Baddest mf'er...ever.
Check your TPS (throttle position sensor)
Here's what my car was doing, see if it's similar
It would drive around fine, but when I let off the throttle, the car would begin to buck wildly. Very annoying when trying to drive through parking lots. (oddly it was also effecting my idle)
I changed the TPS sensor, and all is now good. A faulty TPS sensor will give bad readings to the ECU, like the throttle is open, when it's really closed or vice versa.
Hope this helps. Post this in Engine/Tech, ask 1stGenCrx, he knows everything and helped me with my problem
Old May 15, 2003 | 05:25 PM
  #35
ExiledinIN's Avatar
ExiledinIN
If there was a recall on the ignition switch, that would be your culprit. Did you receive a recall notice on your car? I know on the Preludes it took 2 months before I got mine. And before then I had replaced it myself. The switch is $30 some dollars and takes about 1 hour to do (wasn't very hard, just one difficult screw). If it is the same P/N as the Prelude, I have an extra...
honda1998civic
92+ Civic/EL & Del Sol
May 21, 2012 04:00 AM
droopy1592
Engine Swaps, Tech & Tuning
7
Sep 18, 2004 11:05 PM
97Civic123
Do It Yourself
2
Apr 1, 2003 10:04 AM
BobRafferty
CRX & Pre 92 Civic
3
Sep 21, 2002 02:56 PM
