Fuel System problems
Old May 28, 2005 | 03:36 PM
chenzzo's Avatar
chenzzo
Default Fuel System problems
Hey guys, I've got a 95 Del Sol and I'm having a major problem with my fuel system. I put the car out for sale on the side of the road and less than a week later somebody stole my seats out of it. I tried to drive the car home (while sitting on a stool) so I could get new seats and put them in and suddenly the car won't start.
My brother (a mechanic) and I look at it and determine the engine isn't getting any gas. We took the top hose off the fuel filter and no gas was coming out when you tried to start the car. We figured hey maybe the fuel filter is bad, let's take the bottom hose off and see if we're getting gas coming into the filter.
No dice.
Process of elimination leads us to the fuel pump. I take out the back console and replace the fuel pump. Still nothing, no gas making it through the lines to the fuel filter and the engine.
Okay. Must be the main relay. Looking through the Chilton manual makes it seem like it must be that. We need to test it and see. Take out the relay, run a jumper (some speaker wire) from the relay's battery terminal slot to the fuel filter terminal slot and when we turn on the key you can suddenly hear the fuel filter start pumping.
Eureka!! Must be the main relay, right? No fuel pumping with it in, fuel pumps when we bypass it. So I get a new main relay and plug it in. Still nothing. Can't hear the pump come on and no gas is getting to the engine.
So do any of you guys have any idea what else could be the problem? Thanks in advance for your help.
-chenzzo
Old May 28, 2005 | 03:46 PM
honura's Avatar
honura
Seni
May sounds stupid but there is a connector that SCREWS into the engine near the thermostat. It is screwed in by a 10mm bolt. If this is not grounded correctly it can cause the fuel line to die. Check it and see what happends. Even if it's tight just remove it and clean it a bit. GOODLUCK..
Check all the fuses as well. Don't be stupid and over look that because sometimes the easy things are the problem.
Old May 28, 2005 | 05:40 PM
Wharbone's Avatar
Wharbone
check your fuses. Maybe you blew a fuse when you jumped the relay.
Old May 28, 2005 | 08:39 PM
FATHONDA's Avatar
FATHONDA
hehe, you think the lines got smashered?
Old May 29, 2005 | 04:25 AM
chenzzo's Avatar
chenzzo
which fuses should I check? The ones under the dash or the ones under the hood?
-chenzzo
Old May 29, 2005 | 12:43 PM
FATHONDA's Avatar
FATHONDA
ignition switch, check the wires. they may have tried to steal the car.
Old May 29, 2005 | 10:06 PM
Wharbone's Avatar
Wharbone
-chenzzo
For a 92-95 civic, the fuses to check are:
under dash - fuse 18, 7.5a, PGM-FI ECU, PGM-FI ECU Main relay
under hood - fuse 31, 15a, PGM-FI Main relay
fuse 32, 7.5a, PGM-FI ECU, Clock
You might as well check all your fuses while you are at it. It is easy.
Old May 30, 2005 | 05:05 PM
chenzzo's Avatar
chenzzo
the ignition switch still seems to be working. The car is turning over it's just not getting any gas.
Old May 30, 2005 | 05:06 PM
chenzzo's Avatar
chenzzo
Thanks Wharbone, I'll do that.
You guys have been very helpful.
Old May 30, 2005 | 08:40 PM
Wharbone's Avatar
Wharbone
If you're not getting gas, it is most likely a fuse, main relay, or the fuel pump. Sometimes it can be a bad ECU also, although this is rare (it happened to me a couple of years ago).
I'm sure there are other things that could be causing your problem, but these would be the most likely.
Good luck finding it. Let us know when you figure it out.
