SOHC VTEC Swap Question
Old Mar 11, 2005 | 01:42 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Originally Posted by westcoaststyle
D15B7 is a 92-95 Civic DX (and probably a hatch trim as well, but not sure off the top of my head h: )
92-95 LX (coupe and sedan)
92-95 DX (hatch, coupe and sedan.)
Old Mar 11, 2005 | 10:18 PM
JaVa_230's Avatar
JaVa_230
Originally Posted by 1fasthb
Drop in some dohc zc pistons with the y8 head and you will get some really good hp numbers.
then why not just swap in the whole d16? it wont be much more for the block.
Old Mar 12, 2005 | 09:19 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
Originally Posted by Cashis EG8
I remember about two years ago, I was looking into a Mini-me swap, but after I calculated all the costs, it would be cheaper to just swap in a whole SOHC VTEC motor.
The only time a mini-me is worth it, IMO, is when you have a spare VTEC head lying around with all the parts.
the head swaps give you slightly higher compression numbers, so I'd do that vs. swaping the whole motor
Old Mar 12, 2005 | 04:30 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Find a D16Z6 online for 500$, and get a different size head gasket, or pistons... And you got higher or lower compression..
Also, if you swap in a Z6 motor, I am guessing its going to have fewer miles than your motor has. oposed to just swaping the head, you are going to get more out of a total engine swap, for the same price of a head swap..
P.S. Somewhat of a relation to the topic, but, when my head cracked on my H23, it was cheaper to import a motor, and swap the entire motor than to replace the head.
Old Mar 12, 2005 | 05:49 PM
19.3secS2K's Avatar
19.3secS2K
z6 is the 5th gen ex. y8/y7/y5 are all 6th gen engines...
and other than vtec, intake/exhaust manifolds and a few minor things, there's little to no difference between the y7 and y8, so the head swap would be just fine.
Old Mar 14, 2005 | 06:49 PM
Ziken's Avatar
Ziken
RACE USE ONLY
If I do the swap, will i have to get a different ECU? Which ecu should i use?
Old Mar 14, 2005 | 08:30 PM
19.3secS2K's Avatar
19.3secS2K
you need to change the ecu as well, the same as the head you get, be it a z6 or a y8
Old Mar 15, 2005 | 07:54 PM
Kabuki's Avatar
Kabuki
No, you don't... You need to stick with an ECU that can be programmed, which at this point is going to be an OBD1 ECU. If your car is OBD1, then stick with a P28 or P72 ECU. If it's OBD2, then use something like a P2P. But for love of pete, just stop insisting on using OBD2 ECU's just because the engine was in an OBD2 car, that it needs to be treated as such.
Old Mar 15, 2005 | 09:20 PM
Ziken's Avatar
Ziken
RACE USE ONLY
sorry for my noobness, what is a p2p?
Old Mar 16, 2005 | 05:24 PM
racerdave's Avatar
racerdave
USAF C-17 Crewchief
Who cares, if you buy a motor, just use what you have. If it works then why change it?
P.S. a 94 D16Z6 uses OBD-?
