NEED HELP 98 ex turbo
Old Aug 21, 2002 | 06:08 PM
reddemon009's Avatar
reddemon009
Default NEED HELP 98 ex turbo
i have a 96 dx. i jus swapped a 98 ex motor in with a greddy turbo kit. the damm thing doesnt work. the car starts up fine it has a lil eratic idle but as soon as i touch the throttle it stalls out. im using a 94 ex ecu but i have tried a 96 ex ecu and it does the same thing. when the engine was out i changed the head gasket and timing belt. i cheked everything over i have no idea wats wrong. i cheked the engine codes and im getting a o2 sensor code and another one i dont know wat it is its coming up as code 2. that code is not in my book i have. im using a 96 ex o2 sensor so thats probally y im gettin that code but still the car should run w/o it. if any one could help i would really appricate it.
Old Aug 21, 2002 | 09:45 PM
Smurf's Avatar
Smurf
Dancing Banana Driver
wow ...
crapy deal. go check all wires, unplug them and plug em back in
Old Aug 22, 2002 | 01:58 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
Check your timing belt timing. It sounds retarded.
Old Aug 22, 2002 | 04:23 AM
Guest
Guest
Posts: n/a
Well check this out. Do any of you remember when I had that problem when I swapped that JDM D15B into the DX? Well anyway, it would start but it ran like crap and then would die if I pressed the gas, I checked everything you could think of. Finally we had it towed to a shop and one of the brand new spark plug wires was faulty. that is all it was. Also, check your firing order. Had I known more about testing electrical components Iwould have caught it.
Old Aug 23, 2002 | 11:05 AM
reddemon009
ill check all the electrical componets but i dunno if thats it. i hooked up a air/feul gauge and im running really lean. it doesnt move off the red on the gauge. so i think it mite b a feul problem but i dunno how everything was working b 4 i blew my motor.
Old Aug 23, 2002 | 11:10 AM
bret's Avatar
bret
my hood fits like shit
are you getting enough fuel?
Old Aug 27, 2002 | 06:38 PM
reddemon009
i found out the problem.. i had the map sensor and tps backwards. lol at least it wasnt anything major.
Dime333
92+ Civic/EL & Del Sol
9
Feb 3, 2006 10:06 AM
Whitelude420
Prelude
May 27, 2003 05:20 AM
Cord 2oo1
Accord
Mar 19, 2003 04:09 PM
