Lowering help
Old Aug 19, 2002 | 05:39 AM
Paulll's Avatar
Paulll
Hail Bent
So...
If I lower the front 1" and the back 1.5", get some new shocks(Agx???), and a camber kit, i'll be fine right?
Also, I wanted to lift my car back up to the stock height for the winter, would there be any problems there?
Thanks
Old Aug 19, 2002 | 05:59 AM
third demon's Avatar
third demon
It all depends on the car,some non lowered civics need camber kits.There are a lot of variables .Lowering any car will give you positive camber which will make the car handle better,but too much will wear tires,best thing to do is to lower your car,take it to the alignment shop and have them check your camber and then go from there..
Old Aug 19, 2002 | 01:56 PM
Paulll's Avatar
Paulll
Hail Bent
Old Aug 19, 2002 | 02:13 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
if you need to change the ride height for winter your cheapest solution would be a coilover kit.
with coilovers, aftermarket struts, and a camber kit you will be more than ok lowering oyur car that much.
and any decent alignment shop will tell you that you need a camber kit, because actually doing the job RIGHT requires one. there are always shortcuts, and i wont argue there, but right == camber kit.
Old Aug 19, 2002 | 03:09 PM
Paulll's Avatar
Paulll
Hail Bent
What is your input on the best kind of camber kit. I think that i am getting AGX shocks and GC coilovers...
Old Aug 19, 2002 | 03:26 PM
Fujiwara Takumi
It's my first day.
well, i have "specialty products" -- seemed to be of decent quality, they seem fine.
seems to me "progressive" is the way to go, but i may be wrong.
Old Aug 19, 2002 | 05:11 PM
civic2k2grl's Avatar
civic2k2grl
Originally posted by Max Power
civic2k2grl, wat year civic do you have?
with 7th gen they changed the suspension design, i think (not sure) they no longer use double wishbones.
when my friend got his sportlines installed on his 01 civic they said it was absolutely neccassary to get a camber kit.
juss pointing this out because the newer suspension design mite be affected differently by lowering.
ihave a 2002 civic now but i had a 94.. most of my experiance is with the 94 not the new one
Old Aug 19, 2002 | 06:25 PM
Quikstep's Avatar
Quikstep
OG Swollen Member
Lowering your car gives you Negative camber.
Old Feb 8, 2003 | 07:24 PM
speed614's Avatar
speed614
Civic GSR Driver
what about a 1.75 drop? camber kit for sure? Also put in aftermarket struts to play it safe?
Old Feb 8, 2003 | 07:41 PM
Paulll's Avatar
Paulll
Hail Bent
DIE THREAD DIE
