"dimple drilling"?
Old Aug 15, 2002 | 09:42 AM
4-banging's Avatar
4-banging
Default "dimple drilling"?
has anyone heard of this?
this is the quote i got from the guy i purchased my brembo rotors from after i asked if the holes were supposed to be drilled all the way thru..they were drilled and slotted by an aftermarket company.
"The new way of drilling is called DIMPLE drilling. It helps keep the shape of the rotors. Alot of people say that drilling all the way through weakens the rotors so doing it this way keep more metal on the rotor and works the same. Please leave me feedback, thanks!
XXX"
Old Aug 15, 2002 | 10:09 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Less surface area equals less braking surface. You need surface area to brake. Dimples are just a sales gimmick like cross drilled rotors are nowadays.
Autocross Help Page
Old Aug 15, 2002 | 10:16 AM
skubb's Avatar
skubb
not that TLC sh!t either
um I'm not sure your ever supposed to tamper with the surface at all. I would've bought em cross drilled or slotted in the first place.
what happens when you lock em up and they explode cause some dikweed "dimpled" them wrong?
Old Aug 15, 2002 | 10:33 AM
4-banging's Avatar
4-banging
should i finish drilling them my self? or just leave it alone?
Old Aug 15, 2002 | 10:37 AM
Nelson's Avatar
Nelson
Administrator
Default Re: "dimple drilling"?
XXX"
WTF? "Dimple Drilling"... doesn't that just defeat the purpose of CROSS DRILLED rotors? That's bullsh*t . That's why I'd rather get Brembo parts direct from a real Brembo distributor.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Aug 15, 2002 | 10:42 AM
Duff Man's Avatar
Duff Man
Default Re: Re: "dimple drilling"?
:eh:
:werd:
Old Aug 15, 2002 | 11:33 AM
wilsel's Avatar
wilsel
On the other hand, more surface area = faster cooling. In this case the pads have less of a surface to grab, but the rotor has more surface area to expel heat. "Dimple Drilling" will not decrease the strength of the rotor itself as much as cross drilling will. For a daily driver regular rotors should suffice. It's really up to you to decide if they are going to be functional for you. Europes best cars come with slot drilled rotors stock.
Old Aug 15, 2002 | 12:29 PM
4-banging's Avatar
4-banging
i'll just test them out for a couple of months and see what the difference is....if it's noticeable.
Old Aug 15, 2002 | 12:31 PM
dantastic's Avatar
dantastic
cx power!
hmmm... sounds like slotted rotors but with dots insetad of slots
Old Aug 15, 2002 | 01:27 PM
qtiger's Avatar
qtiger
Yes, but slots are designed to expel hot gas whereas dimples are not.
