B18c + b16a = ????...
Old Sep 26, 2004 | 01:35 PM
cashizslick's Avatar
cashizslick
Originally Posted by carlitosir
I ask for a b16a2
The guy says that the one he got for me was in real bad shape or something and instead he was gonna give me this(b18-b16 sh*t) + headers and ITR tranny.
should I complain and ask them to get that engine out of there ?
(the car still not done although the engine is already on the car)
Also, how about reliability?
why not see if you can get a B16 head for cheep and have them pay for it?
Old Sep 26, 2004 | 01:36 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
if you're using stock pistons, you probably wont want the compression bump of the gs-r head anyway... at least not if youre turboing it.
Old Sep 27, 2004 | 05:08 AM
carlitosir's Avatar
carlitosir
Originally Posted by Andy
If the work is done properly, a new headgasket, new headbolts, the head and block are flush and everything's torqued properly, you shouldn't have a problem, it will be a strong as stock but if the engine's been ragged on and the heads just slapped on, your going have issues, especially witha turbo. I'd consider looking elsewhere for your engine.
Oh no; about that I have no complaints. I know they did an excellent job installing the engine (all new belts, new water and oil pump, gaskets, flushed block and head, new brackets etc.). He even showed me all the internals and they were looking prety fine
What im worying about is this.
if you're using stock pistons, you probably wont want the compression bump of the gs-r head anyway... at least not if youre turboing it..
I want new pistons anyways but I didnt think about it earlier
Old Sep 27, 2004 | 07:02 AM
white_n_slow
it's my D in a B
time to pull out the wallet :happysad:
Old Sep 27, 2004 | 07:27 AM
carlitosir's Avatar
carlitosir
:thinking: should be really expensive "laborwise" now with the engine already on the car!!!!?
if it is i'll wait till i have the money to do it & get it boosted all at once.
Old Sep 27, 2004 | 08:00 AM
Kestrel's Avatar
Kestrel
Push to shock!
Well if it runs now (it sounds like this setup is already in your car) then you might as well drive it around for now. If you are running boost, then you will eventually have to think about replacing your pistons anyway, so you could just do it then.
