all those who fixed their camber with washers
Old Aug 15, 2002 | 07:26 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Originally posted by Jkan2001
I don't know what they are talking about because the bolts go into the frame just like the original ones....they are just longer. I had to use quite a few washers on mine...i think 3 on one side and 3 or 4 on the other. I have a 1.8" drop on factory shocks...which are actually holding up pretty well surprisingly, I've had them for around 2 years.
the original ones dont go into frame either, look at your helms manual. they go into like a soft body mount. its not something that can take a ton of stress.
Old Aug 15, 2002 | 07:31 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
hrmm i never noticed it just went into the subframe...in any case the bolts aren't the part that are taking the most stress anyways
Old Aug 15, 2002 | 07:34 AM
Fujiwara Takumi
It's my first day.
agreed, but it was something a very good alignment/suspension shop warned me to be wary of, so i would almost have to agree with them. The worst thing that could happen is both bolts sheer off under a hard impact... that wouldbe traumatic, but id bet youd lose a decent piece or two of your underbody.
btw...you never noticed...do you do your own work?
Old Aug 15, 2002 | 08:17 AM
4-banging's Avatar
4-banging
what about on a eibach sportline/kyb-agx set up? (rear only)
I plan on getting the skunk2 set up for the front.
Old Aug 15, 2002 | 08:49 AM
Fujiwara Takumi
It's my first day.
toe/ camber is directly related to modified height. the lower you go, the worse ti gets. my rear has got to be off like 3 degrees, (maybe even 4-5), minumum. my fronts were between 1-2 i would imagine
Old Aug 15, 2002 | 08:52 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Yeah i actually did it myself....i just shoved the longer bolt in where the stock one was...didn't really look inside to see how far it went in. I guess i just assummed that it was safe since it was longer than the stock one so if it was gonna break the stock one would have already broken off before.
Old Aug 15, 2002 | 08:55 AM
Fujiwara Takumi
It's my first day.
sheer strength near the head of the pin vs along the threaded parts will be much stronger, thats why using washers may not be that great of an idea. follow?
Old Aug 15, 2002 | 08:56 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Yep i see what you're saying....i just got grade 8 automotive strength bolts and i've had mine setup like that for over a year....haven't had any problems yet.
Old Aug 15, 2002 | 09:00 AM
Fujiwara Takumi
It's my first day.
lets go do some jumps
Old Aug 15, 2002 | 09:01 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Already have Went over a hill a bit too fast....turned out to be very steep and i got all 4 wheels off the ground....DAMN it was scary. At least everything was intact after i stopped and checked it out....kind of rashed up the bottom of my front lip a bit but i got that fixed
