A/C turns off and on
Old Aug 10, 2004 | 09:24 PM
Zzhatch's Avatar
Zzhatch
the belt spins but i can see the wheel of the compressor stop.
Old Aug 10, 2004 | 10:04 PM
KeepinOnThaDL's Avatar
KeepinOnThaDL
same shit happends to me, its annoying especially when driving with the ac turning off and on and screwing with the rpms. I just released [Reomoved] some freon (r134) from the low side and it seems to be better but not perfect. oh, and can someone tell me if it's normal for green crap to come out of the low side?
Old Aug 11, 2004 | 08:14 AM
Zzhatch's Avatar
Zzhatch
i tried to do that too, but since the compressor wast spinning it wouldnt take the charge! im really hating this situation. what can i do?
Old Aug 11, 2004 | 04:29 PM
Ross's Avatar
Ross
My AC will not auto shut off but it will just pop on once in a wileand i dont know why, i have a 2000 SI civic
Old Aug 11, 2004 | 04:51 PM
CivicRacr's Avatar
CivicRacr
seems like the clutch or field coil is going bad if the compressor isnt spinning but the belt is...that or the compressor is seizing up inside and can cause costly repairs like replacing the compressor, condensor and hoses
edit: is there any signs of oil leaking from the compressor? lets hope its not and its just the clutch/field coil thats going bad
Old Aug 11, 2004 | 08:03 PM
Zzhatch's Avatar
Zzhatch
where is the field coil, and what can i do to check it to make sure it is fine, and how can i check the clutch
no there isnt any oil leaking from the compressor
how much would a field coil be? could the clutch on the compressor be changed?
Old Aug 11, 2004 | 09:46 PM
CivicRacr's Avatar
CivicRacr
the field coil is inside the compressor pully, to get to it you would have to take out the compressor, take off the clutch plate and then the pulley...i wouldnt suggest doing that...uh...but the wires coming from the compressor, you can check the resistance of the field coil...get a multimeter have one connector touching the bare metal of the compressor and the other connector to the wire that goes to the condensor fan (disconnect this plug to test)...resistance should be 3.05-3.35 omhs at 68F...if not probably needs to be replaced
