A/C turns off and on
Old Aug 10, 2004 | 09:34 AM
Zzhatch's Avatar
Zzhatch
Default A/C turns off and on
i have a 92 four door, it has a d15b7 and whenever i turn on the a/c it stays on for about five minutes then it turns off. i looked under the hood and i see the compressor moving then the wheel just stops moving, then it might turn back on after a couple of minutes, then the engine starts vibrating, and it sounds like it is struggling and the a/c turns off again. what could this be???
Old Aug 10, 2004 | 10:28 AM
Kabooki's Avatar
Kabooki
mine does that too,think its normal.
Old Aug 10, 2004 | 10:34 AM
saga's Avatar
saga
broke college kid
I doubt it's normal. I have that engine but I don't have that problem. But then again my A/C pretty much doesn't work so I wouldn't know.
Old Aug 10, 2004 | 11:46 AM
Zzhatch's Avatar
Zzhatch
i really dont think thats normal, and when it stops hot air blows out, thats definately not normal.
Old Aug 10, 2004 | 02:07 PM
Kestrel's Avatar
Kestrel
Push to shock!
Your compressor's pulley wheel is stopping entirely, but everything else spins? That's not normal for sure. I'd check the belt tension, and see if the compressor's pulley is getting stuck.
Old Aug 10, 2004 | 03:11 PM
Kabooki's Avatar
Kabooki
ah, gettin warm isnt normal...mine just cuts off for a while when it gets cold enough. Thought that was what you meant
Old Aug 10, 2004 | 04:23 PM
Human Hybrid's Avatar
Human Hybrid
Could it just be the Pressure cycling switch? I guess if it's doing it's job...it keeps the evaporator from frosting over.......and if it's bad...i guess it's just cutting on and off whenever....? I'm not sure...just a shot in the dark..
Old Aug 10, 2004 | 06:35 PM
eGsr's Avatar
eGsr
User
Too much pressure in the system, probably at the expansion valve. causing too much pressure and therefor causing the engine to vibrate or strugle to keep running. So the pressure switch turns the power to the a/c coil off.
have your ac checked out. Could be costly.
good luck
Old Aug 10, 2004 | 08:27 PM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
good luck
I doubt it's too costly, as you can fbuy a full AC kit for a civic for like 300 dollars on some sites ive seen. I am interested in seeing what the problem is though, I havent heard of it.
Old Aug 10, 2004 | 09:21 PM
Zzhatch's Avatar
Zzhatch
i really dont have the money to be paying a mechanic, what can i do myself to find out the problem?? where is the expansion valve? what should i be looking for?
