ECU question??
Old Jul 28, 2004 | 01:20 PM
dicivicHB's Avatar
dicivicHB
...on Christ's Team...
Default ECU question??
does the civic run a different ECU for manual or auto tranny's? Would i need an ECU from a manual to put in my manual CX? or are they the same? thanks guys
Old Jul 29, 2004 | 01:56 PM
dicivicHB's Avatar
dicivicHB
anyone know?
Old Jul 29, 2004 | 02:05 PM
supermac88's Avatar
supermac88
not OG but Old School
as far as I know they are different
Old Jul 29, 2004 | 02:30 PM
saga's Avatar
saga
broke college kid
I'm almost positive they are different.
Old Jul 29, 2004 | 03:31 PM
civicburner's Avatar
civicburner
I did an auto to manual swap on my car, and I'm currently using my auto computer, and haven't had any problems. My car drives fine
Old Jul 29, 2004 | 05:20 PM
saga's Avatar
saga
broke college kid
I would think it would drive fine. But the auto's are four speed while the manuals are five speed. So I would think that there is a loss of something along the way.
Old Jul 29, 2004 | 06:00 PM
Jafro's Avatar
Jafro
I'm made of meat!
dcivicHB... what motor are you replacing the ecu for? Is it your stock cx engine? That matters more than the transmission because its fuel trims are set to the engine's output and capabilities more than it is to transmission control.
Don't civic automatics have TCU's? I don't know because I don't mess with autos... If they do, the transmission is controlled separately from the ECU. Mitsubishi uses TCU's so it's not uncommon to imports.
PS: I have a perfectly good working CX manual tranny ECU (P05) sitting here.
Old Jul 29, 2004 | 06:37 PM
dicivicHB's Avatar
dicivicHB
thanks jafro...i'm looking to get a d15b7 into my stock manual cx....so i would need the ECU for a manual d15b7....
Old Jul 29, 2004 | 10:31 PM
Jafro's Avatar
Jafro
I'm made of meat!
All you need is a P06 ECU. It won't matter if it's manual or auto. It can even come from an LX, but if you find a DX P06, you're golden for sure.
Edit: For good measure... if you find one on ebay... Ask the seller to provide you with the serial # on it before you buy or bid. It's on a label on the side. Give all of those numbers to a Honda parts counter and they will tell you for sure if it will work on your year chassis. I think there might be something funky on the 92's, but from what I gather 93-95 are the same.
Old Jul 30, 2004 | 09:59 AM
Relic1's Avatar
Relic1
Teal Hatch Cult Member
you can always do the opposite of this to your existing ECU as well.
the instructions are for the P28 but your ECU should be almost identical.
