idle air control valve
Old Aug 8, 2004 | 10:12 AM
  #31
Jafro's Avatar
Jafro
I'm made of meat!
Jones? :thinking:
Old Aug 8, 2004 | 02:09 PM
  #32
geldingmakr's Avatar
geldingmakr
oh... i thought i read jones on your cx time slip...
Old Aug 8, 2004 | 02:58 PM
  #33
Jafro's Avatar
Jafro
I'm made of meat!
Heheh.. Oh. I don't know if that was right or not. Which timeslip? on the CX page? My civic ran the 17.95. That was with the wrong ECU, injectors and 2 codes with a CEL. I was a little anxious to see what it would do.
Old Aug 11, 2004 | 05:57 PM
  #34
geldingmakr
this one on the cx page has a 19.98 against a 15... so i guessed the 19 was you
http://homepage.mac.com/jafro/.Pictu...3cxquarter.jpg
Old Aug 23, 2004 | 05:08 PM
  #35
Jafro's Avatar
Jafro
I'm made of meat!
Oh... I guess I didn't post the "after" timeslip. That was with the old CX motor. I'd better snap a pic of the "after" run before the ink fades into obscurity. My bad.
Old Oct 2, 2004 | 10:53 PM
  #36
89Teg's Avatar
89Teg
Originally Posted by Jafro
Man... when it idles back and forth like that, it's getting the wrong signal. It sounds to me like you swapped your IAT sensor harness and your IACV harness. They have the same plugs. It causes exactly that, but usually you get a check engine light with a code 14.
Something tells me you've done more maintenance to this car than you're telling us. But if it just started doing all this by itself, I've heard of stranger things happening. I know someone that did the thing I listed above to someone else as a practical joke. Wasn't very funny.
This happened to me, I had the connectors switched or so I think. I'm still working on the car, but I'm pretty sure that's what the problem was. What colors are the wires that go to each connector on the harness? If someone can check for sure it would set my mind at ease. I still haven't fuigured this one out because no matter how I try to reset the code it still comes back after a few seconds after turning on the ignition.
