uh-oh! i broke trailing arm- lca bolt
Old Jul 26, 2004 | 09:06 AM
  #61
Kestrel's Avatar
Kestrel
Push to shock!
Originally Posted by docmanakos
Polyurethane bushings are horrible, they squeak all the time, they make your ride much, much harder, and do not make your handling better. Putting firmer less deflectable bushings have absolutely nothing to do with the three most important things concerning handling. Adhesion to the road, which is determined by your tires. Roll and rebound, which is determined by your shocks, swaybars, springs, suspension geometry. sprung and unsprung weight. Suspension balance, this is an area that very few of the "bolt on" enthusiast know much if anything about.
Putting in firmer bushings and subframe connectors, or strut tower braces, do nothing unless your suspension is so firm that now all the stresses and looseness in your suspension is transfered and due to those area's (the weak link the the chain concept). Just because the race only cars have it doesn't mean it's good for you.
Docmanakos@aol.com
Have to disagree with you there. Well, except for the harsher ride and squeaking, that is true. Polyurethane bushings reduce play which is why it's important. If you have play, you will slight unpredictable variations in suspension geometry as a function of road load, acceleration, bump load, etc. Bushings aren't the only suspension thing to look out for, but they are still important.
Old Jul 26, 2004 | 11:17 AM
  #62
lkailburn's Avatar
lkailburn
college kid
suggestions for a replacement nut?
Old Jul 26, 2004 | 12:37 PM
  #63
Jafro's Avatar
Jafro
I'm made of meat!
Match the threads of your bolt with a grade 8 nut, and weld it back on there. I suppose you could just clamp a nut back down on it and ride, but I'd be concerned about it backing off. I'd weld it.
Old Jul 26, 2004 | 02:32 PM
  #64
white_n_slow's Avatar
white_n_slow
it's my D in a B
Docmanakos@aol.com
you, sir, are a sissy.
You also don't seem to understand the most detrimental effect of bushing deflection. As you mentioned, adhesion to the road is determined by the tires... and its your allignment that allows the tires to do their job, determining how much of the tire is in actual contact with the road. When your bushings deflect during hard cornering, your suspension geometry changes significantly. When you corner hard (especially if you have good tires), stock--and especially worn-- bushings can deflect up to ~8mm. This deflection results in a slight change of suspension geometry, adding positive camber to the outside tires (those doing the most work). If you've ever done an allignment or messed with a camber kit, you know that 8mm can make a huge difference. With said squishy bushings, you may have zero static camber, but mid-corner you actualy have positive one (or more) degrees camber, which would make any tire hard-pressed to grip worth a damn.
By minimizing bushing deflection (essentially holding the suspension geometry stable), polyurethane bushings make more efficient use of the tires, maintain dynamic allignment (i.e., keep the allignment of a moving car where you set it when it was still), and isolate suspension movement, making better use of the springs and dampers. Some bushing replacements, like Orijin Motorsports, actually eliminate bushing deflection alltogether with solid a-arm bushings and front LCA spherical bearings.
Old Jul 26, 2004 | 02:44 PM
  #65
Civic2Scooby's Avatar
Civic2Scooby
erhem....wned:
Old Jul 26, 2004 | 05:58 PM
  #66
lkailburn's Avatar
lkailburn
college kid
i'll look for a grade 8 locking nut or a locking washer and normal nut
Old Jul 27, 2004 | 06:21 AM
  #67
s1ngle's Avatar
s1ngle
clutch slipping boost
uh oh hnoes:
Old Oct 9, 2004 | 11:47 AM
  #68
nahatch's Avatar
nahatch
yea the rear lower lca for civics/integras are known to break regardless. the only way to do it easiest is a press... Drilling take alot of constant power and hella expensive concrete bits or titanium ones. Normallly it just breaks were it gos into your strut. I have yet to see one break on the subframe or underneath the disk. The bolt is very strong and are all the same and are 12+ dollars at honda! To me the best way of doing it is a press and if your bushings are messed up just get used lca's from the junkyard .. some are prettty good .
