idle?
Old May 26, 2004 | 06:31 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
lemme see if i can get you a picture of what it looks like
IACV is the thing in the bottom left of the picture. It connects right near the back of the throttle body. All you need to do is unplug the harness connector to it.
Old May 26, 2004 | 06:34 AM
importkustoms00's Avatar
importkustoms00
Korean DOOD
ok that would be very helpful
Old May 26, 2004 | 07:50 AM
importkustoms00
Korean DOOD
um i dont think its the idle screw because as of now when i just checked the idle was fine...what else could it be?
Old May 26, 2004 | 08:57 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
you may need to take the IACV off the manifold and clean it. use some cab cleaner and itll clean right up.
Old May 26, 2004 | 11:42 AM
Cbakey's Avatar
Cbakey
Originally Posted by monicle
to reset the ecu you need to pull the radio/backup fuse from the under hood fuse box for about 10 seconds and put it back in. its a 7.5 amp fuse
What would happen if you ran with out the fuse in the car?
Old May 26, 2004 | 12:04 PM
monicle's Avatar
monicle
Repo.Jackmoves.Com
see if you can get your car started withough it and if you can we will see. good question though. I would imagine it wouldnt hold any settings everytime it was turned off if it even started at all.
Old May 26, 2004 | 12:29 PM
supermac88's Avatar
supermac88
not OG but Old School
wont start at all
Old May 26, 2004 | 01:25 PM
Cbakey's Avatar
Cbakey
humm, well i pulled out that fuse so the raido wouldnt get any power figureing that both needed to be pulled, beocuse my new raido i put in fryed as soon as i started the car so.... than i drove 109 miles with out either raido fuse in and it seemed to act fine, btw mine is a 2000 LX...............
Old May 26, 2004 | 05:34 PM
PHiZ's Avatar
PHiZ
BOOST GOD
http://www.honda.co.uk/owner/CivicManual/pdf/11-72.pdf
-PHiZ
Chris N
13
Mar 29, 2004 11:38 AM
PeckerWood504
Engine Swaps, Tech & Tuning
Jan 25, 2004 09:17 AM
grip
2
Mar 21, 2003 12:57 PM
AwwsChwA
4
Oct 10, 2002 06:17 PM
MoFo
7
Aug 31, 2002 11:14 AM
