idle?
Old May 25, 2004 | 05:05 AM
importkustoms00's Avatar
importkustoms00
Korean DOOD
Default idle?
i have a fluctuating idle? how to fix? it runs about 1500 when cold buts runs low (almost cutting off when its warm) btw
Old May 25, 2004 | 05:53 PM
importkustoms00
Korean DOOD
bumpity
Old May 25, 2004 | 07:57 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
mines looks like it runs 600, when idle... but my cel light error is O2 sensor. Dont wanna pay 80$ for sensor
Old May 26, 2004 | 01:31 AM
LoumeX's Avatar
LoumeX
got comfused of your problems.whats wrong mine is nearly 900 thats normal i guess!
Old May 26, 2004 | 04:48 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
you need to probably reset your idle speed.
after your car is warmed up and while running unplig your icav (your car will probably stall) start it up again and slowly take your foot off the accelerator and you should be able to get it to idle even though its really low. then use your idle adjust screw on the throttle body to get it to idle right about at 800 or so. turn off the car and reset your ecu. plug in your iacv. start the car without touching the accelerator and let it idle for about a minute. youre good to go.
loumex, nice avatar. One Piece is the shit.
Old May 26, 2004 | 06:18 AM
importkustoms00
Korean DOOD
ok im not very mechanic friendly whats is the icav? and how do i reset the ecu?
Old May 26, 2004 | 06:20 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
iacv=intake air controll valve. its located on the back of the intakemanifold. and to reset the ecu you need to pull the radio/backup fuse from the under hood fuse box for about 10 seconds and put it back in. its a 7.5 amp fuse
Old May 26, 2004 | 06:21 AM
LoumeX's Avatar
LoumeX
thNX man i kinda know it!kicks ass...
Old May 26, 2004 | 06:24 AM
importkustoms00
Korean DOOD
thanx i got try to fix it now
Old May 26, 2004 | 06:29 AM
importkustoms00
Korean DOOD
is it a hose? or what? also which one is the idle screw?
