rev limiter
Old Apr 18, 2004 | 06:34 PM
civicracer03's Avatar
civicracer03
Default rev limiter
Is hondata the best way to go if i wanted to remove the rev limiter on my civic?
Old Apr 18, 2004 | 06:38 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
For what reason would you possibly want to remove your rev limiter?
If you're done some serious tuning to your engine, and want to have your car tuned, yes a hondata would be awsome.
if you just want a coverall cheap way to remove it, go on ebay and buy a chipped ECU - much cheaper that way. Although I think no rev limiter would be STUPID
Old Apr 18, 2004 | 06:51 PM
shivers's Avatar
shivers
Moderator Alumni
Most people just move the rev limit up to take advantage of the power band from aftermarket cams. Personally, I wouldn't ever remove a rev limiter completely.
2005 s2000
Old Apr 18, 2004 | 08:20 PM
Civic2Scooby's Avatar
Civic2Scooby
ummm why the hell would you remove it....move it up yean...but removing it mite be the most retarded thing I have ever heard.
Old Apr 18, 2004 | 08:31 PM
Jafro's Avatar
Jafro
I'm made of meat!
I hope you've replaced your valve springs already. Moving the rev limiter without upgrading valve springs is a great recipe for valve float, burnt valves, crashed valves, or worse. But you didn't specify why you're considering this, or anything else about your car, so I'll just go back to lurking and keep my mouth shut.
Old Apr 18, 2004 | 08:32 PM
Civic2Scooby
lol...I was just assuming that he already upgraded his ish
Old Apr 19, 2004 | 01:05 PM
wilsel's Avatar
wilsel
Unless you've done some serious work your car would already be past peak HP at the stock rev limit. Going further wouldn't help, and is very risky.
Old Apr 19, 2004 | 01:10 PM
Civic2Scooby
so to sum up this thread.....only push your rev limiter as far as you need it to go while still making power...it is pointless to rev out to 11k if you stop making power at 8k....
Old Apr 20, 2004 | 03:54 PM
s1ngle's Avatar
s1ngle
clutch slipping boost
Has anyone ventured to up their limiter on a stock engine? im interested in knowing the results.
Old Apr 20, 2004 | 04:06 PM
Kai's Avatar
Kai
Rotorphile.
You have a rev limiter for three reasons.
1) It keeps the engine running within it's mechanical limits.
2) It keeps the engine from running far outside it's powerband (you make NO extra power above the limiter on a stock engine, in fact the power drops off fast)
3) It keeps idiots from blowing up their engines.
fastrnuGSR
19
May 10, 2004 08:26 AM
doIhaveBDIs
CRX & Pre 92 Civic
7
Aug 18, 2003 07:47 PM
WojtekG
Engine Swaps, Tech & Tuning
2
May 26, 2003 02:24 AM
ZiviCase10287
6
Mar 24, 2003 02:48 AM
kane
Accord
25
Aug 5, 2002 06:28 AM
