does gsr have rev limiter?
Old Feb 7, 2004 | 07:06 PM
fastrnuGSR's Avatar
fastrnuGSR
Default does gsr have rev limiter?
i have a 95 GSR. does that have a rev limiter or fuel cut off? i used to have a 96 Honda Accord Lx (manual) and it had no rev limiter, just fuel cut off at about 6900 rpms.
Old Feb 7, 2004 | 08:11 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The fuel cutoff is the rev limiter. When the engine reaches a certain rpm, the fuel cuts off which stops it from revving any higher. The rev limit on a GSR is 8400 rpm.
Old Feb 7, 2004 | 09:53 PM
twin3037's Avatar
twin3037
i've always found mine to shut off the fuel right at 8200 occiosanlly barelly higher though
Old Feb 9, 2004 | 06:36 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
The OEM tach's aren't extremely accurate so...
the stock cut is 8400 like booty said.
Old May 6, 2004 | 09:09 PM
GSR4444's Avatar
GSR4444
If your car is at warm operating temperature, and u hit the rev limiter at 8200-8400 rpm, what could possibly go wrong? I hit the rev limiter in 2nd gear yesterday, being retarded and not payin attention to the tach, car runs just like normal, anything i should be worried about? 50k on engine
Old May 6, 2004 | 09:23 PM
Kai's Avatar
Kai
Rotorphile.
Nothing will go wrong because you hit rev limit (within reason on a stock engine) besides the accellerated wear caused by being at that high of an RPM.
Unless, of course, you hold it for a while. That could result in oil starvation and a spun rod bearing and the like.
Old May 6, 2004 | 09:37 PM
GSR4444's Avatar
GSR4444
nope, didn't hold it. As soon as i noticed that the revs started to bounce, i immediatley shifted.
what do u mean by
Old May 6, 2004 | 09:48 PM
Kai's Avatar
Kai
Rotorphile.
An engine wears faster at high RPM.
Imagine sanding a peice of wood, rubbing it once a second with the sandpaper.
Now imagine rubbing that peice of wood seven times a second with the sandpaper.
The wood wears down faster when you sand it faster, right? Same general idea with the friction surfaces inside of your engine, but a lot slower. An engine ran at a constant 1k RPM will outlast an engine running a constant 7k RPM, ignoring things like oil starvation and carbon buildup.
Old May 6, 2004 | 11:33 PM
clabbe's Avatar
clabbe
Could you lift the rev limit yourself on any simple way, or do you need skills in chips or programming in the ECU?
I mean is there any "manual" way you could raise it?
Old May 6, 2004 | 11:34 PM
Kai's Avatar
Kai
Rotorphile.
There is absolutely no good reason to do that, short of a lot of engine work.
and no, there is no "easy" way to raise it.
