b20 BS thread....
my bum is on the swedish!
good luck. the 99+ engine is damn hard to get a hold of. I tried for about 8 months before I gave up. Basically, the only way to get it is through a local wrecked CR-V. The major engine importers (hmotors, total boost, etc) generally don't import many of them, and when they do, a local shop or regular customer usually had dibs on it. If you find a reliable source let me know.
import yards here usually have shit. I just want to know what I'm talking about before I go talk to them.....
Originally Posted by b16aEGcivic
you will need an LS or other intake mani, because the CRV mani wont fit....as far as the rest goes it is just like putting a b18b into your car.
anyone have experience with the skunk2 nonvtec IM?
or should I just use OEM ls.....
Originally Posted by Paulll
I agree with b16a, If you cannot find the b20, just go ahead and find a b18a/b.
or maybe its the ft/lbs......
if you get a USDM B20Z, the intake manifold *should* fit. With a JDM motor, it definitely will not. By "should" I mean i've seen a few sites that say it does, but I've never seen it in person or a photograph. If you remove the resonation chamber on the B20Z and block it off, the stock manifold will definitely fit. Otherwise, LS is the most cost effective option, and creates a pretty desirable powerband.
As for the other stuff, you'll need a clutch and flywheel, since most (if not all :thinking: CRVs are auto) also the stock CRV alternator wont fit right, so an LS one will do the trick. Aside from that, its all basic B-series swap stuff.
Do you have any plans to boost whatever engine you get?
clutch & brake assembly
clutch resivoir & master cylinder
tranny mount
axles
tranny fluid
harness (i dunno)
ecu (i dunno)
tranny mount
axles
tranny fluid
harness (i dunno)
ecu (i dunno)
