Idle problem
Old Feb 18, 2004 | 05:47 PM
theguy386's Avatar
theguy386
I am tehguy... OH YEAH!!
Default Idle problem
Ok this started happenning, last night. I took off and I was going about 5mph then the car just stalled but the clutch was in. And it happened again this morning :wtf: Then my car idles from 900 to 1200 RPM's when I'm a complete stop. If I'm going at a constant speed (40 mph, 3000 RPM) then the RPM's will drop as if though I put in the clutch and let it out real quick. I think it might be my injectors, but I'm not sure. What do you guys think??
Old Feb 18, 2004 | 06:49 PM
honura's Avatar
honura
Seni
Sounds to me like a sensor or a vac is no good . Take a look at everything and make sure all vacs are hooked up . Do you get a CEL ? If so what are the codes ?
Old Feb 18, 2004 | 07:27 PM
cvcsleeper's Avatar
cvcsleeper
Boyashaka!
True, sometimes the secondary O2 sensor will be giving bad readings, consequently the ECU will be adjusting the air/fuel ratio. So if the O2 sensor is constantly giving incorrect readings, that would cause your idle to increase and decrease w/o warning.
Check for cracked or broken vaccum lines. That has most often been the source of my problems in the past.
Good luck :thumbup:
Old Feb 19, 2004 | 05:43 PM
theguy386's Avatar
theguy386
not to be a noob or anything, but do you have a pic of these VAC's??
Old Feb 19, 2004 | 09:25 PM
Civic2Scooby's Avatar
Civic2Scooby
could also be a bad Idle Air control Valve...from what you are saying that would be my best guess, but yeah like Honura said...you throwin any codes? also what year is your car..cause that will dismiss or affirm the second o2 sensor theory
Old Feb 20, 2004 | 12:36 PM
theguy386's Avatar
theguy386
its a 95 D16z6. Where would I check for these CEL codes?
xavierfg
CRX & Pre 92 Civic
5
Sep 3, 2003 06:02 AM
Pimpin Olds
Engine Swaps, Tech & Tuning
Aug 28, 2003 03:01 AM
bearlan
Jun 30, 2003 01:16 PM
LewisT
Accord
Mar 17, 2003 06:12 AM
LewisT
Mar 16, 2003 06:38 PM
