89 Accord idle fluctuation problem
Old Mar 16, 2003 | 04:20 PM
LewisT's Avatar
LewisT
Default 89 Accord idle fluctuation problem
Hello. I own an 89' Accord LXI (fuel injection) that is experiencing problems w/ the idle speed. The idle speed goes up and down when the engine is cold or is warm (up and down and up and down .....).
I pulled and cleaned the fast idle valve, the electronic air control valve and bled the cooling system through the bleader bolts but none if this helped. I did not check - the throttle position valve or the map sensor. Could either of these cause the problem or is it something else. Any comments would be appreciated. Thanks in advance.
Old Mar 16, 2003 | 06:38 PM
XSrcing's Avatar
XSrcing
have you checked the vacuum hoses for any leaks?
