Short ram
Old Feb 24, 2004 | 10:15 AM
  #101
sky-sol's Avatar
sky-sol
lets get funk-a-fied
i don't think i need a bypass valve, i put the wheel well back where it goes, it's not going to stay open like that, and I don't think that the air would be that much disrupted as it went over the little ridges, I mean it would go over those same ridges if i had it stock.
Old Feb 24, 2004 | 10:20 AM
  #102
sxecrow's Avatar
sxecrow
Banned
The valve is to get water out that is sucked up thru there. If you go thru a deep enough puddle, theoretically it could suck up the water. Spend the 40 bucks for the saftey measure. TX has lots of tornados and rain. Why risk the engine you can't afford to blow?
Old Feb 24, 2004 | 01:01 PM
  #103
sky-sol's Avatar
sky-sol
everyone says that the filter has to be completely submerged to get hydrolock. If i see a puddle i can dodge it, and if the streets are flooded i'll stay at home.
EDIT: North Texas has lots of tornados, down by Houston I have only seen one, we have lots of hurricanes, maybe not as many as you, and it does rain alot by Galveston and Houston.
Old Feb 24, 2004 | 05:44 PM
  #104
sky-sol's Avatar
sky-sol
well i got one more clamp thing so now my UGAI (ultimate gettho air intake) is now working, i must say that i can feel the difference and it seems to be alot quiter. I also got some tube and reconected my crack case thing up so i hope that makes things better to, i'm so execited :yes:
Old Feb 24, 2004 | 06:20 PM
  #105
Dr. Isotope's Avatar
Dr. Isotope
If you just put your stock airbox where the rubber pipe is, you can acheive the same results with less ghetto-ification. And you wouldn't even need a bypass valve.
Old Feb 24, 2004 | 07:38 PM
  #106
sky-sol's Avatar
sky-sol
i don't mind the ghettoness, no one is going to see it and if i'm ever going to get an engine swap i'll put the stock back on :yes:
Old Feb 25, 2004 | 05:12 AM
  #107
sxecrow's Avatar
sxecrow
Banned
No you wont :chuckles:
bulwinkle
Accord
15
May 19, 2003 07:30 PM
ZiviCase10287
Engine Swaps, Tech & Tuning
14
Mar 10, 2003 06:40 PM
PoRnStAr840
RSX & 02-05 Civic Si
11
Feb 6, 2003 09:24 PM
integraXP
Aug 17, 2002 04:52 AM
