Originally posted by Kai I would need some pictures to believe this. Take a picture of the distributor showing the grey plugs, the head, and the head casting date showing at least a '92 casting.
An older DOHC ZC will bolt in to a 5G with little work, however they use some weird distributors. If your distributor is only held on by two bolts, it's probably the old blacktop rewired with a grey plug harness.
rite now my b16a first gen has all the plugs from a 95 eg because I swapped over the wiring harness to convert the motor to obd-1....I am sure all the guy did was take the obd-0 zc motor and swap over the harness the dizzy and the injectors....viola grey plugged zc motor.
