dohc d16zc
Does anybody know about this motor?
All I know is it came out of a 93 eg from japan.It has gray plug,not yellow. And my 94 lx transmission bolts up to it.
Any help would be helpful.
Thanks
Thanks
this motor is in my car. The guy I got it from said it was rare,and it did come out of a 93. It looks just like the older dohc zc but has gray plugs,and bolts right up with no mods.Is there any place I can go to find out more?
I would need some pictures to believe this. Take a picture of the distributor showing the grey plugs, the head, and the head casting date showing at least a '92 casting.
An older DOHC ZC will bolt in to a 5G with little work, however they use some weird distributors. If your distributor is only held on by two bolts, it's probably the old blacktop rewired with a grey plug harness.
look above the exhaust manifold on the front of the head. It will have a set of circular stamps, one of which will have a two number year code split by a vertical bar.
ie, (9|2) for 1992, it may be tilted.
