92 Accord Wagon. 5 Speed Manual. $3600. St David, AZ 85630
sold to first person to view it
Original owners were a couple that leased the car. Long term owner was a woman, Emeritus Professor - retired, Department of Psychology at ASU (owned car from July 1994 (31,902) miles to 2020 (169k miles). She bought the car in 1994 when in her 50s.
Well maintained and not abused. Not modified. Has always been a southern Arizona car. No rust. Runs and drives great. Everything works, except the power antenna which does work manually. Has an after-market CD/Radio but the original radio comes with the vehicle.Full size spare.
Non smoker owners.
Original paint in very good condition, but does have some scratches.
Garaged.
5 Keys
Some Maintenance highlights
8/1/00 Manual transmission fluid, spark plugs, distributor rotor,distributor cap, brake fluid, engine coolant, radiator, valve cover gasket, condenser fan motor, air filter. 91,849
11/15/02 Manual transmission fluid, spark plugs, distributor rotor,distributor cap, brake fluid, engine coolant, valve cover gasket, air filter. 119,020
11/12/04 Ignitor, right inner and outer cv boot, 134,854
Front brake pads, resurfaced rotors, rear brake shoes. 144,544
1/24/08 Timing belt, balance shaft belt, water pump, tensioner pulley, coolant, 2 "v" belts, cam seal,cam tower o-rings, crank seal, balance shaft retainer, gasket, spark plugs, air filter, distributor rotor, brake fluid, transmission fluid. 149,902
10/10/08 Rear main seal, pressure plate, clutch disc, throwout bearing. 152,483
4/7/10 New oil pan (due to oil leak), oil pan gasket, new brake proportioning valve, new sway bar end link bushings. 158,573
8/10/10 Clutch master cylinder, right side motor mount, transmission mount. 161,610
4/20/11 Four new KYB struts, Right rack bellow replaced, alignment. 164,630
4/12/12 Manual transmission fluid, air filter. 167,596
2015 Three new tires at Discount tire. 168,637. Fourth tire matches with most of tread remaining.
1/22/20 Distributor o-ring, distributor seal, P.steering high pressure hose, PS fluid, oil and filter. 168,747
New Interstate Battery, 24 month free exchange. Manufactured June 2020.
12/23/20 New OEM Denso Starter motor. 169,400
The car is quiet, but the muffler should be replaced. The rest of the exhaust system looks very good.
For more photos and/or question, please PM or reply here.
Located in Saint David, AZ approx 1 hour from Tucson.
$3500
Non smoker owners.
Garaged.
5 Keys
$3500
eclipse spanker
11
Jul 29, 2002 12:31 PM
