Help !!
Old Dec 28, 2005 | 07:27 PM
loafeidb's Avatar
loafeidb
Default Help !!
OK , now my car has reached 90000 miles at which time honda`s service 90000 mile is recommended well my dealer is asking 1400 for this service so i thought that was kinda harsh and he took it down to about 1200 tax included, my license is going to be suspended now for a little while because of 2 moving violations within 24 months of each other ,so this is where my question comes in ....
Wouldnt it be a little more cost efficient if i were to get a b16 and then install it myself over this time period , instead of spending 1200 to service my car , i know the b16 isnt going to be 1200 but its worth the extra money , but now i want to know how extensive is it (on a scale of 1-10) i should be able to get a hold of most of the tools needed like a "cherry picker" and those things... i have also read a lot of builds info but if you have more links please list them as they would really help. i basically want to know what all i should replace while im in there and if I will be able to install everything with just basic knowledge of engines and such.
Thank you
Old Dec 28, 2005 | 07:36 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
Cant you do the work yourself?
Im sure the service is new plugs, wires, rotor, cap, and oil change at most
Old Dec 28, 2005 | 07:56 PM
loafeidb's Avatar
loafeidb
Engine oil and filter - replace
Fluid levels - top off all
Lube hinges, locks, latches, and hood cable
Front / Rear brakes - visual inspection
Transmission fluid - drain & refill
Lights - check operation
Clutch - adjust if applicable
Battery posts - inspect & clean
Fuel lines, tank, lines & connections - inspect
Spark plugs - replace (except platinum plugs)
Distributor cap & rotor - inspect
Tires - balance rear tires and rotate to front; adjust pressure & inspect tire wear pattern
Coolant system - Check level & test protection
Wiper blades - check operation & wear
Park brake - adjust & lube as needed
Front/Rear disc calipers & hoses
Air filter - inspect
Exhaust system - inspect
Suspension, struts & steering - inspect
Adjust valve clearance if applicable
Brake Fluid - replace and bleed system
Engine timing belt
inspect water pump & accessory drive belts for wear and damage.
and see the parents want to whip out the money but i was also thinking about getting something better out of the deal . and atleast have a project to work on while my car sits in the garage
Old Dec 28, 2005 | 08:19 PM
PDiggityDogg
Ok, well I say just do all that yourself and save your parents $1000
Old Dec 28, 2005 | 10:17 PM
'98 EX RED's Avatar
'98 EX RED
King of the Auto Civic
The only "hard" thinks are timing belt and water pump.
Old Dec 28, 2005 | 10:31 PM
loafeidb's Avatar
loafeidb
the way i feel about it is that basically even if i go ahead and do this service, im going to swap the motor anyways so why spend the time and money to service this one. so basically i just want a thumbs up or down for the swap, basically is it worth it , what all i need except the parts and also i am plannig on turboing this motor in the future but in the later future ,
Old Dec 29, 2005 | 05:32 AM
PDiggityDogg
I dont know why people spend that much money for an engine with the same displacement when a b18a/b is less, easier to boost, and has more tq
so...thumbsdown
Old Dec 29, 2005 | 07:05 AM
loafeidb's Avatar
loafeidb
I agree but the b18b doesnt have vtec does it?
and i havent seen an b18a but the b18c motors are a little too expensive for me at this moment
Old Dec 29, 2005 | 07:45 AM
PDiggityDogg
vtec is really really overrated
Old Dec 29, 2005 | 08:44 AM
'98 EX RED's Avatar
'98 EX RED
but it is very, very nice.
