80 thousand
Old Mar 7, 2004 | 05:41 PM
Vibralux's Avatar
Vibralux
Rollerblader
Default 80 thousand
im new to the new look of HA.N. i had a different account before, but with the name was silly, and i wasn't taken to seriously. so i started fresh.
anyway, i have a 95 ls that is coming up on 80k in about 9 miles. is there a major service at that? what can i expect when i go in?
Old Mar 7, 2004 | 07:40 PM
Daniel's Avatar
Daniel
Hey, welcome back! :thumbup:
Your last maintenance should have been at 75k miles which included the following:
  • Replace engine oil
  • Replace engine oil filter
  • Replace engine coolant
  • Inspect front and rear brakes
  • Check parking brake adjustment
  • Rotate tires
Visually inspect the following items
  • Tie-rod ends, steering gear box, and boots
  • Suspension components
  • Driveshaft boots
  • Brake hoses and lines (including ABS)
  • All fluid levels and condition of fluid
  • Cooling system hoses and connections
  • Exhaust system
  • Fuel lines and connections
Your next service interval is at 90k and will include the following:
  • Replace air cleaner element
  • Inspect valve clearance
  • Replace spark plugs
  • Inspect and adjust drive belts
  • Replace transmission fluid
  • Replace brake fluid
  • Rotate tires
  • Driveshaft boots
  • Exhaust system
Old Mar 7, 2004 | 08:14 PM
timmy8151's Avatar
timmy8151
Another common maintenance item at 90K is the replacement of the Timing belt and waterpump.
thork
8
Feb 25, 2004 08:16 PM
Jessica
Sep 4, 2003 07:59 PM
