ITR vs M3 on the track
sometime in the near future i am going to sell the GSR and get either an E36 M3 or an ITR. i like them both a lot but i am concerned with preformance. which is a better track car. i know the ITR is great but the M3 is RWD and has more hp and torque. i have spoken with owners of each and done some additional research and it seems to me that the M is better, but maybe im missing something. thanks in advance for ur help
given equal driver i would give the edge to M3 but not by too much.
however if budget is an issue itr might be a better route.
M3 suspension parts (aftermarket) is pretty expensive.
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
Originally Posted by WiLL
M3 will be significantly faster on track, with the same driver.
240hp, 225hp and RWD will blow away a high strung 200hp and FWD. Its just faster. I blistered 2 front tires trying to keep up with one at CMP earlier this year.
Originally Posted by flyromeo3
ITR will pull out of turns and enter turns better than the M3.
Its pretty interesting to see these differences first hand, on track between the two cars. Rather than bench racing or "i heard about... "
Originally Posted by .RJ
No way. Torque + RWD will pull out of the hole alot harder than FWD and Torquesteer/Understeer. Thats probably the biggest place the M3 has an edge. Straightline speed once out of the corner, they're fairly equal and an ITR can make up time under braking and in high speed corners.
i often go against e30, e36 M3s and ITRs at the track...of course i'm running 7lbs boost so i can stay with them...the M3s are pretty dominant coming out of corners when done correctly and its torque gets them moving pretty fast...but in the esses or carousel's the itr has a definite advantage with its lighter weight
Originally Posted by EVO VIII
I would have to agree the ITR would go better into turns and exit better than a M3
he said the M3 has the edge.
LCD Squad #0001
LCD Squad #0001
Yeah... gotta love that FWD exit acceleration!
(edited for immaturity) by jaje
