Did my own alignment today.
Old Apr 2, 2004 | 12:15 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Default Did my own alignment today.
Oh yeah that was fun I borrowed someone's toe plates and was fiddling around with which way to turn the darn arm I kept turning each side the wrong way. I was at 1/2" toe out then 3/4" toe out
Finally got it through my thick skull and ended up with 0 toe and the car drives straight yeah!
Autocross Help Page
Old Apr 2, 2004 | 01:38 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
how does the toe plates work??? I would like to do my own alingment it would save me some money
Old Apr 2, 2004 | 06:22 PM
CivicSiRacer
They are two L shaped plates that sit against each of your wheels. Then you use measuring tape (hopefully acurate with each other) and put one tape on the front of the plate (wheel/tire) and another on the back of the plate (wheel/tire) and measure the differences between the two.
So if the front tape is at 70" and the rear tape is at 69" then you have toe out (which 1" of toe out IS ALOT!). If it's the other way around it's toe in.
I'll take a picture for you tomorrow.
There's also the string method which is also very easy to use.
Here are some other methods:
http://honda-tech.com/zerothread?id=267237
http://www.racerpartswholesale.com/long18.htm
http://www.honda-tech.com/zerothread?id=597192
Autocross Help Page
Old Apr 2, 2004 | 06:24 PM
Solracer's Avatar
Solracer
NASA-VA Hyper-Announcer
That Jerry Birchmore's Car?
Old Apr 3, 2004 | 02:43 AM
CivicSiRacer
Here's a pic of the toe plates:
Autocross Help Page
Old Apr 7, 2004 | 08:00 AM
.RJ's Avatar
.RJ
Go Fast Crack Whore
You can also use something like this:
http://racerpartswholesale.com/long18.htm
Old Apr 7, 2004 | 09:17 AM
CivicSiRacer
I thought about that too. I'm so used to using toe plates now
Autocross Help Page
Old Apr 7, 2004 | 09:25 AM
mohamed_ibrah's Avatar
mohamed_ibrah
Tech in Training
Wow, I give you guys props :goodjob: , it's a lost art apparently, I can't and don't know how to use those manual methods and have to use the Hunter machine instead. Tried the Visualiner machine, but didn't like it.
Old Apr 7, 2004 | 12:12 PM
CivicSiRacer
Well I change my settings at least once a month. So going to get it done at NTB or Pep Boys would make me broke and no more money for racing
Autocross Help Page
Old Apr 13, 2004 | 04:22 AM
Neo's Avatar
Neo
Originally Posted by CivicSiRacer
... and ended up with 0 toe and the car drives straight yeah!
Cool. Did you end up with having the steering wheel centered as well? That's my biggest fear about these DIY alignment jobs.
