Hoosier A3S03 225/45/15
Old Feb 25, 2004 | 07:45 AM
dadios4's Avatar
dadios4
Will these fit on the front stock 15x6 USDM ITR rims or do you have to move to a 225/50/15 (which are not available on the Hoosier A3S03).
TIA
Old Feb 27, 2004 | 04:24 AM
B( * Y * )BIES
Guest
Posts: n/a
IMO - the 225/45 & the 225/50 are to wide for the 6" rim.
I think you'd have better success using at least a 15x7.
Let's see what others say about this.
Old Feb 27, 2004 | 07:28 PM
nw98typer's Avatar
nw98typer
Both the 225/45-15 and the 225/50-15 will fit the ITR 15x6 rims.
I know from experience that the 225 Victo's require a spacer to prevent the tire from rubbing. I'd be willing to bet that the 225's from Hoosier also require the spacers. The spacers that I use are 5mm.
What are you using the 225's for? Most DS cars are running 225's front and 205's rear.
I hope this helps.
Old Feb 28, 2004 | 06:58 AM
dadios4's Avatar
dadios4
nw98typer, the tires will be used for DS autocross...I'm sure your right the 225s will probably require a spacer. Thanks
Old Feb 29, 2004 | 05:22 PM
bbqman's Avatar
bbqman
225/45 fit on a DS ITR without spacers in the front ....no problem. I used this set up all last year.
Old Mar 1, 2004 | 08:04 AM
nsxtasy
Guest
Posts: n/a
There are two different fitment issues here: (1) Can the tires be mounted on wheels of that width? and (2) Will tires that size rub? Other folks seem to be mostly answering question 2.
To see whether a given tire can be mounted on a given width of wheel, you can check the specs for the tire on the tire manufacturer's website and/or on the Tire Rack website. According to the Tire Rack website, this size is only approved for rim widths of 7 to 9 inches. So the answer is no, the 225/45-15 will not fit on the stock 15x6 rims.
Old Mar 1, 2004 | 09:03 PM
nw98typer's Avatar
nw98typer
The 225's will fit on a 6 inch rim. Although I personally run Kumho's I have a friend who is running the 225's Hoosiers on Millenia's.
BBQ, Since you run the Hoosiers, can you please confirm that your running them on a 6" rim.
Thanks.
Old Mar 2, 2004 | 04:38 PM
bbqman's Avatar
bbqman
Sounds crazy but it is very true. You CAN fit a 225/45 on a 6 inch rim.
While this is not ideal nor recommended from most tire manufacturers, we know it works and is a must if you expect to be competitive at the National level.
All top DS ITR's run the 225/45 in the front for auto-x. Most without spacers...no issues!
Old Mar 2, 2004 | 05:47 PM
.RJ's Avatar
.RJ
Originally Posted by nsxtasy
(1) Can the tires be mounted n wheels of that width? and (2) Will tires that size rub? Other folks seem to be mostly answering question 2.
Because if you are running a stock class autocross car, your rim width must be stock. And all of the "fast" guys just stuff as much tire as will fit on that wheel and still fit inside the fender.
Its not optimal, and a wider wheel will be faster, but its still faster than running 205's - although the new Hoosier A3S04 and Kumho 710 are getting very, very weide....
Old Mar 9, 2004 | 11:00 AM
Chris N
Guest
Posts: n/a
Yep, you can squeeze those 225/45's on stock rims... amazingly enough.
The newer tires, like RJ said, are getting very wide, I dont think you'd be able to use the new Hoosier in particular without a spacer....
