Problem with new Azenis'
Old Aug 3, 2002 | 04:44 PM
Sir Revalot's Avatar
Sir Revalot
Default Problem with new Azenis'
They were just mounted today and at full lock they rub. They are 205/50/15 on GSR 15x6 wheels. I'm not really that low. I'm running koni yellows with neuspeed sports, with the yellows on the low perches. I guess I have two options, live with the rubbing at full lock or I can raise the car a perch on the shocks. I'd rather not do the latter cause I'd have to basically unassemble each corner. Any suggestions?
Edit: Oh yeah, the car is a 94 Civic coupe.
Old Aug 3, 2002 | 05:15 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Where is the rubbing? on the suspension? inner splash pan? or fender?
-Harry
AIM: NDcissive
Old Aug 3, 2002 | 07:19 PM
qtiger's Avatar
qtiger
Azenis, in general, run a little bigger than their stated size.
Old Aug 4, 2002 | 01:09 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I rub at full lock and at huge dips or hard turns during autocross
Autocross Help Page
Old Aug 4, 2002 | 07:19 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
what's the tire life on those tires.
i bought some in march and well i'm looking to order another pair very soon...
Project EVA - The Track Package
Project EVA
Old Aug 4, 2002 | 04:49 PM
Sir Revalot
I found it out. There is a lump in the liner that is rubbing near full lock. I may just cut it out for now. I might still raise the car cause I don't really like it where it sits. Now I have another question. My yellows have three perch spots in the front and only two in the back. If I do raise the car, I should go up one perch all around, right? That should just give me the drop of the springs without the additional drop of the shocks, correct?
Old Aug 5, 2002 | 02:58 AM
CivicSiRacer
Got mine in January 2002. Done two track days (4 hours of track time), 18-20 autocrosses, 30 laps around the Carlisle mini road course, and 8000 street miles on them and I got tons of tread left. I'm figuring about 20-25K miles from them just regular street driving.
Also realize I have 1.5 negative camber front and 2.2 rear, 0 toe all around, dropped 2" and the tires are on 15x7" wheels.
Autocross Help Page
Old Aug 5, 2002 | 04:02 AM
1stGenCRXer
That depends on how the spacing is setup on the shocks. If you don't like how low it is, raise it up and take a look and adjust from there. If you just don' t like the rubbing, leave it alone and the plastic will form itself or use a heat gun to form the plastic out of the way, or chop it out.
Old Aug 5, 2002 | 07:09 AM
slickboy's Avatar
slickboy
ECHC junkee
The Azenis are a wide tire..but more stick is better. In the 205/50/15 size..the Azenis have about a 3/4" per tire wider contact patch than the Kumho Ecsta Supras do...and mixed with a very sticky rubber compund for a non R-Compund tire, means good traction on the course and great traction for daily driving. I saw the Azenis in action this past weekend..great tire for the money.
Old Aug 5, 2002 | 07:32 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
yeah i figured it was my camber.
but 20-25k seems real good for those tires. they are quite sticky.
i wonder how much more sticky the a032r's from yokohama are from the azeneis. and those things last for like 10,000 miles at the most
Project EVA
