check engine light from fram oil filter
Old Sep 5, 2003 | 05:39 PM
dubcac's Avatar
dubcac
I
Originally posted by Nightshade
Thanks Dub
:werd:
I've found it's much easier to post those links than try and explain it :chuckles:
Old Sep 5, 2003 | 05:48 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
search buttons are neat...
A_D's Avatar
A_D
Reset?
ok i did take my exhaust manifold guard thing off and i did unplug my o2 sensor and forgot to put it on, thats what code i was setting off. but i plugged it back and it still says its not plugged
Old Sep 5, 2003 | 05:49 PM
Fujiwara Takumi
It's my first day.
you need to clear your ECU.
pull your negative battery lead for 10 mins and try it again
should go away.
Old Sep 5, 2003 | 05:50 PM
Luis's Avatar
Luis
Civic1.6VTEC
reset the computer. and no, i never had any bad experiences using fram.
Old Sep 5, 2003 | 05:54 PM
A_D's Avatar
A_D
Reset?
ok my 02 sensor was all it was. i guess my filter is fine. the lights not on anymore. thanks a ton you guys. you ****in rock
