lil_1_2002's gonna be running his.................
Originally posted by crucial Si-T
next up, youre all going to tell me i PS it
Now where is the slip if the time you went recently with the turbo and you pulled a 15.7? haha that i ahve to see...
Originally posted by qtiger
I don't think anyone would be dumb enough to PS a slow time.
Originally posted by lil_1_2002
here is my slip....so you dont say anything stupid about me not posting...i'm on the left...now as you can see my trap speeds were way too low...i ****ed up tire pressure was probably too low...which means i could have done better, probably low 15's....
As for your turbo setup costing less? maybe maybe not...and even if it did your still the stupid one for turboing a car with 163k miles...and then claiming you dont want to use it anymore...my engine cost about the same as your turbo...and i run better times...and its stock...throw in some cams...i/h/e...tuning i'm in the mid 13's with a good motor...and not a POS turbo setup that will blow my motor likes yours.
your e/t mph is toooooo low.
my turbo kit NEW cost me $1000 plus tax. bov and fuel setup cost another $2xx so your motor was cheaper than that?
anyhow, you must not know anything about load and turbos, you need load to boost, if the clutch cant hold the crank, then nothing gets to the ground. i havent got a clutch yet, because i have a bad tranny also. i wasnt going to drop the tranny and put in a new clutch, then do a tranny swap later on...thats just stupid.
like i said, i ran almost 10 more mph than you did, i wonder what i would do when im actually boosting over 5.5 psi with traction on the clutch...
Originally posted by dubster99
92 = high 14's with traction.
damn my tires
reminds me i should go to the tracks
Originally posted by airon
i trap that high and i get low 15's
damn my tires
damn my tires
exactly...my trap were wayyy too low...my tire pressure was off. and of course i had absolutely no traction from all the torque in first and second.
you ran a 15.4 @83mph...HAHAHAHAHA BULLSHIT.
Have you ever heard of knowing how to drive? Look at your 60' and then look at his. Every tenth of a second off your 60' is worth 2 tenths in the 1/4. Thus people run a faster E/T at the same MPH on slicks.....faster 60' time.
Accordhybrid
