pc cooling techniques?
Old Jun 30, 2003 | 02:08 PM
b00gers's Avatar
b00gers
Originally posted by sman789
I have two 80CFM fans hat are ouder than hair dryers....i turned them down with a fanbus but i also have 6 other fans cooling the system
i cant imagine the noise from a couple 80cfm fans.
heres the fan that cools my hard drives.
File Type: jpg
Old Jun 30, 2003 | 02:11 PM
b00gers's Avatar
b00gers
Originally posted by spankaveli
how much is water cooling? and how much of a difference would it make?
im looking seriously into a hard drive cooler because thats what i think is causing the most heat
a harddrive cooler is no more than $20 right? give it a try.
water cooling is a good $200 im guessing. but its mostly for the CPU.
DakarM's Avatar
DakarM
Originally posted by sxecrow
I have a 10,000 RPM ultra 2 wide scsi drive for my OS. It gets hot at 10k RPM so I have a HD cooler on it. The drive is significantly cooler. If the room is hot because of the computer, turn on the AC on or (forgive me for even suggesting it) turn the computer off.
:werd:
I have 2 15K rpm SCSI drives and 4 10K rpm scsi drives.
The 4 10Ks are in a dedicated hot swap enclosure with 2 fans to cool them. The 2 15Ks are cooled the single 120mm fan in the back sucking out all the hot air.
then there are the 4 5400rpm ide drives... umm two of those are in the case so they sort of get cooled and the other two are outside the case. :doh:
everytimes I fire up that puppy the room temp goes up by a good 3-4F in 30mins :chuckles:
however I will say that when I had 2 CRTs in the room it got a lot hotter.
It's a lot cooler with the LCDs.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Jun 30, 2003 | 02:13 PM
94civicEX's Avatar
94civicEX
I got worms.
I just set my fan in front of it b4 I go anywhere h:.
99 Integra GSR
06 TSX
duck squad member #00003
Old Jun 30, 2003 | 02:27 PM
sman789's Avatar
sman789
Don't touch me I'm tender
i'll get pics of my case.....i was gonna say clear the airways in the case but yours is nice
Old Jun 30, 2003 | 02:35 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
AEM CAI
Old Jun 30, 2003 | 02:54 PM
sman789's Avatar
sman789
UV light on top a back...an 80 CFM for the back and one on the side for exhaust...a 120mm 50cfm for front intake....and instead of a hdd i put two 80mm fans on top of my HDD
then a small 60mm on the bottom back
i turned all on low so its quiet
The system is cold but my room get really hot from the exhaust, the only way to cool your room is to turn on the AC
like 94civicex....cheapos who dont want watercooling buy personal AC's small enought to put in front of your PC
Old Jun 30, 2003 | 04:08 PM
LX4CYL's Avatar
LX4CYL
Cone Basher
I have a 15k RPM IBM SCSI drive at work in a Dell Poweredge w/ no extra cooling. It sit's in a closet with no ventilation
yep, I've got the Antec SX830 w/ 8 fans:
Enermax Power Supply= 2
Rear= 2 (80mm)
Front= 2 (80mm)
Geforce3= 1
CPU= 1
8 total :thumbup:
Old Jun 30, 2003 | 04:19 PM
Whiskey Tango's Avatar
Whiskey Tango
mines a stock powerspec setup:thumbup:
Old Jun 30, 2003 | 04:22 PM
HondaRacer023's Avatar
HondaRacer023
Damnit just take the cover out and put it near the window. and I bet the monitor makes more heat than your comp. unless you have LCD.
