a lil help with susp swap.
Old Jun 29, 2003 | 11:37 AM
b00gers's Avatar
b00gers
Default a lil help with susp swap.
im getting ready to take my ground controls off. this is my first time doing it all by myself, so i want to make sure i have everything straight.
i took off the front wheel, and the front looks pretty straight forward.
i took off the rear and had a little trouble trying to figure out which bolts to remove.
can someone give me a how to on how to do the rear of a 99 integra sedan. im pretty sure its similar if not the same as the coupes.
here is what i have so far.
-remove the 2 nuts that are accessible from the trunk area, the nuts used to hold in a rear strut bar.
-remove the bolt / nut that holds the "fork" of the shock to the control arm
can someone take over from there? i know i have to remove a LCA bolt, not exactly sure which one. heres a pic.
thanks for the input. also, if there is a DIY online, can you please link it. i seen the one from c-speed already.
File Type: jpg
Old Jun 29, 2003 | 11:48 AM
FDragger's Avatar
FDragger
the F is a secret :shhh:
remove the bolt on the opposite side of the arrow and the whole assembly should come out
File Type: jpg
Old Jun 29, 2003 | 11:49 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
First thing, remove that red part..... that'll make it a lot easier.
Old Jun 29, 2003 | 11:53 AM
b00gers's Avatar
b00gers
what red part? the shock? :slap:
Old Jun 29, 2003 | 11:54 AM
b00gers's Avatar
b00gers
is that the only bolt that has to be removed from the LCA? thanks.
Old Jun 29, 2003 | 11:56 AM
dubcac's Avatar
dubcac
I
Only bolt
Old Jun 29, 2003 | 12:05 PM
b00gers's Avatar
b00gers
any tips for making it as easy as can be.
-rent spring compressor
-breaker bar
-pentrating oil
Old Jun 29, 2003 | 12:07 PM
AP2's Avatar
AP2
Moderator Alumni
You don't need a spring compressor since your car is already lowered. So there shouldn't be any preload when you are loosening the top nut. Don't need a breaker bar. WD-40 will help if you do run into some bitchy nuts.
Why are you taking them off?
Old Jun 29, 2003 | 12:08 PM
FDragger's Avatar
FDragger
maybe spray the bolt with some WD-40 and let it soak a little if it doesn't want to come off.
what are you replacing the GC's with? you only need a spring compressor if you are putting factory springs back on. me and my friend actually just use brute force and didn't need a compressor.
breaker bars are for weaklings
Old Jun 29, 2003 | 12:09 PM
dubcac's Avatar
dubcac
I
He's putting ITR springs back on, so he'll need the compressor.
