a lil help with susp swap.
Originally posted by DC2
You don't need a spring compressor since your car is already lowered. So there shouldn't be any preload when you are loosening the top nut. Don't need a breaker bar. WD-40 will help if you do run into some bitchy nuts.
Why are you taking them off?
Originally posted by FDragger
maybe spray the bolt with some WD-40 and let it soak a little if it doesn't want to come off.
what are you replacing the GC's with? you only need a spring compressor if you are putting factory springs back on. me and my friend actually just use brute force and didn't need a compressor.
breaker bars are for weaklings
h:
:fawk:
Originally posted by WiLL
im going back to the oem springs. just slowly going back to oem specs. :happysad:
:squint:
:shocked:
