Jeep Cherokee Starting Issues
Old May 6, 2010 | 12:42 PM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
Default Jeep Cherokee Starting Issues
I know alot of you guys have or know about Jeeps so I have a question.
2001 Jeep Cherokee I6. Starting when cold results in cranking for a good 5 seconds. There seems to be no difference when cold starting if I pump the gas or let the car prime a few times.
Warm starting isnt much better, maybe starts in 3-5 seconds.
Im trying to look where to start with this issue. I was trying to replace the fuel filter until I found out its all contained in the fuel pump as 1 unit :wtc:
nightshade et all halp h:
Old May 6, 2010 | 12:51 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Fuel
spark
air
The only three things that an engine used to need :chuckles:
Is the starter turning slow or is it turning normal speed and just not firing?
Old May 6, 2010 | 12:52 PM
dubcac's Avatar
dubcac
I
Starter
Old May 6, 2010 | 12:54 PM
DarkStarr's Avatar
DarkStarr
Shake n Bake!
skelly ftl
Old May 6, 2010 | 12:57 PM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
Starter turns like a champ.
I recently changed plugs and wire tube thingys FYI
Im thinking fuel
skelly FTW
Old May 6, 2010 | 12:59 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Im thinking fuel
skelly FTW
Did you gap your plugs or just toss them in?
Check all the wires and connections you changed?
Old May 6, 2010 | 01:00 PM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
Plugs were gapped. After i changed the plugs and wires the jeep ran fine for 3 months. Recently this started happening.
Old May 6, 2010 | 01:01 PM
LOL @ :wtc:
Old May 6, 2010 | 01:05 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Check all wires to the starter. There is a single small one that leads to...uhh something (I forget right now) that if it comes loose can play hell with you.
Is this consistent or intermittent at all?
I would be checking the plug wires for consistent spark as well, it happens sometimes that one will go bad. I would also pull the plugs and check the ends for carbon build up or oil etc. while there I would get a leakdown compression check as well. Simple to do and since you are in the neighborhood and all that.
Old May 6, 2010 | 01:13 PM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
Hearing your responses so far are you thinking its a spark issue?
I can pull the plugs and check to make sure everything is good with the wires to the starter.
