Math Help
Old Jan 21, 2009 | 03:06 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
I just called them and the dude figured out my question in less than 2 minutes from me reading him the problem...but I still don't understand
LT's Avatar
LT
The deer had to die!
Got it.
Old Jan 21, 2009 | 03:07 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Originally Posted by LT
Got it.
...and? :bs:
Old Jan 21, 2009 | 03:12 PM
LT's Avatar
LT
this might help
File Type: jpg
Old Jan 21, 2009 | 03:28 PM
F22B Prelude
Rachel Bilson
Thanks, but don't forget the open hole at (-1, 11)
Old Jan 21, 2009 | 03:34 PM
Red X's Avatar
Red X
x pǝɹ
Find all values of x where the function is discontinuous ....
g(x) = 11 if x < 2
x^2 + 2 if -1 < or equal x < or equal 3
11 if x > 3
I don't understand whats happening:
-1<=x<=3 then y=x^2+2
x<2 then y=11
x > 3 then y = 11
You have a conflict with the definition: x can't take on two values (i.e. be x^2+2 @x<=3 and also be 11@x<2). Are you sure its not x<-2 ?
But by either definition I don't think its discontinuous anywhere. A discontinuity (I thought) was when you had no y-values for a range of x. It appears you have either more than 1 value of y for an x OR only a 1:1 map (a defined, continuous function).
Old Jan 21, 2009 | 03:43 PM
F22B Prelude
Rachel Bilson
x<2 then y=11
x > 3 then y = 11
My bad I merged two problems
11 if x < -1
Old Jan 21, 2009 | 03:44 PM
Originally Posted by dj02
came here to post that
Old Jan 21, 2009 | 03:56 PM
Red X's Avatar
Red X
x pǝɹ
11 if x < -1
For this one you have to know how the range is defined. Is this function defined for all real numbers? If so, then it is discontinuous when x >= -1. If y=0 when x>-1 then its discontinuous (there's a jump) @ x=-1.
-1 <=x <=3; y=x^2 + 2
x > 3; y= 11
Similarly, this would be discontinuous outside the range if you are dealing with real numbers. So whenever x<-1.
In all cases, if x was limited by the definition in the right way(say x could only take on values >-1) then the function in problem #2 could never be discontinuous.
Notice that @x=3, y=11 which is the same when x>3, this means there is no 'jump' or discontinuity at that point. i.e. the limit as you approach from the right is the same as the left.
Old Jan 21, 2009 | 04:09 PM
For this one you have to know how range is defined. Is this function defined for all real numbers? If so, then it is discontinuous when x >= -1.
and heres the red one.
