9 Volt Battery Flash Drive
Old Aug 25, 2007 | 07:02 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Default 9 Volt Battery Flash Drive
So I got bored a little bit ago and decided to do something fun.
Ingredients:
1 1gb Flash Drive
1 9 volt battery
1 needle nose pliers
3 packing peanuts
1 knife
Using the pliers I opened up the 9volt battery and pulled out the guts(6 small AAA batteries). I took the piece of cardboard from the back end and cut a slot for the USB plug to fit into. Then I pulled the terminals from the battery pack and put the terminals back in using a tad bit of super glue, which didn't hold.
Then I opened up the flashdrive case and took out the circuits. I split 2 packing peanuts partically in half to fit the flash drive inside. I cut the third peanut in half and crammed it into the battery case, to hold the terminals in.
Sorry for the blurry picture.
I then stuffed the drive with the peanuts into the case and closed up the ends.
Viola!
It turned out nice. I looked on Google and didn't see anyone else doing this, so I figured I'd see how it went.
I think I'll go back and replace the soft packing peanuts with hard styrofoam. When I put it into the computer it moves around too much. I'll also close it up cleaner and perhaps paint the scratches. I also want to add an LED into the terminals that lights up when its in use.
Old Aug 25, 2007 | 07:04 PM
AcuraFanatic's Avatar
AcuraFanatic
A true nerd.
Old Aug 25, 2007 | 07:05 PM
RB's Avatar
RB
snitches get stitches
for good reason.
Old Aug 25, 2007 | 07:07 PM
Brar's Avatar
Brar
too big
Old Aug 25, 2007 | 07:28 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Originally Posted by RB
for good reason.
And why is that? People do it with all sorts of things. Rubber ducks, legos, barbies, even bowling balls. Why not this?
Originally Posted by Brar
too big
Its not that big really. I don't care much. I don't carry it around with me all the time.
Old Aug 25, 2007 | 07:30 PM
sinthetiq's Avatar
sinthetiq
what are you, a terrorist?
Old Aug 25, 2007 | 07:32 PM
RB's Avatar
RB
Because it's dumb?
Old Aug 25, 2007 | 07:36 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Yup. I plan to use an army of 9 volt battery thumb drives to take over every country.
Because it's dumb?
:hsdunno: So? I was bored, I had a dead 9 volt and wanted to do something with it.
Old Aug 25, 2007 | 07:43 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
cool stuff man! geeky? yes. but hell, why the hell not!
Old Aug 25, 2007 | 08:00 PM
Brar's Avatar
Brar
so... are you actually going to use it?
if not can I have it?
