no where is plastic used to dissipate heat. the coolant flows into a waterblock with a smooth metal base that are securely mated to processors, chipsets, whatever needs cooling, etc.. the flowing coolant (water, whatever) picks up the heat, carries it out to a radiator where the heat dissipates... like a radiator on an engine.
All I saw were plastic tubes going into a computer. Is water cooling a common practice or did this guy have to fabricate the heatsinks too?
much like you find rubber hoses in your engine bay..
the parts that actually make contact to points that need cooling have to be made of metal, and they are. the metal base pulls the heat off the processor or whatever, and the coolant pulls the heat off the base and carries it away.
water cooling on PCs is quite popular now and has been going on for several years..
