Subwoofer hookup?
Old Nov 10, 2006 | 02:07 PM
2001TEGGSR's Avatar
2001TEGGSR
Is the RF amp a Mono amp, or Mono Block by chance? Whats the impedance?
If it has multiple channels, did you bridge it? If the sub is a 4 ohm, and your amp is a 2 ohm then you overpowered it. Walmart -> Take that shiz back!
Old Nov 10, 2006 | 02:48 PM
Misa's Avatar
Misa
Pic Whore
Originally Posted by Omniscient
I'm out of ideas then I've done two or three systems that were runing over rms.
cheaper subs have lower tolerances :dunno:
we dont know if he was blasting his music at peak or not
we dont know if he wired it up right or not.
Old Nov 10, 2006 | 03:40 PM
useless's Avatar
useless
i like cheese
distortion ftl
Old Nov 10, 2006 | 03:45 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Under powering is as bad as over powering
Just because a sub is capable of running 150 watts doesn't mean you should run 150. In fact a lot of that depends on if you are running clean power or dirty power. My guess is since you are going cheap all around is that you have no crossover to clean the signal up so you are most likely cranking up the gains on the amp and running it straight to the sub. Also most likely is that you are running it full range into the sub and causing even more damage.
Do some research into how to run clean power and what RMS ratings actually mean before you do something dumb for a third time
Old Nov 10, 2006 | 03:56 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Mmm the smell of blown subwoofers!
Does the cone of the woofer move at all when you push on it?
i thought the title said "hooker" intsead
Old Nov 10, 2006 | 04:03 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
A little overpowering is a good thing, but I would go over maybe 20-25 watts over.
Old Nov 10, 2006 | 04:44 PM
b00gers's Avatar
b00gers
Way to start a thread with too little info then leave
Old Nov 10, 2006 | 04:57 PM
:rofl: at walmart sub
Old Nov 10, 2006 | 09:40 PM
niqtorious's Avatar
niqtorious
i really dont know anything about subwoofers and shit, i got it all hooked up at best buy.
http://www.rockfordfosgate.com/produ...n_US&p_status=
^amp
http://www.pioneerelectronics.com/pn...677103,00.html
^sub
as soon as i got it hooked up i had a family friend of mine check it out, he said all the wires looked good, so it sounded like it was hooked up right...
i dont know much, but maybe u guys could help me choose a new subwoofer to go with my amp?
im looking for something below like $150
any help would be great
