Building a computer: Advice
Originally Posted by Wharbone
Well, it seems the more I research this computer build, the more confuesed I get.
Anyways, how does the AMD Athlon X2 4400+ compare to the Pentium D 950? I was surprised that the Pentium D is actually cheaper.
Here is a break down of the chips.
AMD X2 4400+ $460
2.2GHz
FSB: ?
HT: 2000MHz
L1: 128KB+128KB
L2: 2 x 1MB
Process Type: 90 nm
Hyper-Transport Support: Yes
Multimedia Instruction: MMX, SSE, SSE2, SSE3, 3DNOW! Professional
Pentium D 950 $342
3.4GHz
FSB: 800MHz
HT: ?
L1: 24KB+32KB
L2: 2 x 2MB
Process Type: 65nm
Hyper-Transport Support: No
I honestly don't know how to interpret these numbers. Is the Pentium a faster and better processer?
AMD X2 4400+ $460
2.2GHz
FSB: ?
HT: 2000MHz
L1: 128KB+128KB
L2: 2 x 1MB
Process Type: 90 nm
Pentium D 950 $342
3.4GHz
FSB: 800MHz
HT: ?
L1: 24KB+32KB
L2: 2 x 2MB
Process Type: 65nm
The way AMD gets it's 4400 number is to say it performs at about the same speed as an Intel chip clocked at 4.4GHZ (4400MHZ).
AMD doesn't use a FSB in the traditional sence. So take the FSB: ? and HT: ? out completely, as they are not good comparison.
Here, check out this site, it'll give you a pretty good comparison between CPU's. In short, there's not a huge diffrence between them, but the AMD does come out on top.
http://www23.tomshardware.com/cpu.ht...=74&model2=320
Here, I compared them for you. Of the tests on that site, the AMD wins. Sometimes a lot, sometimes just by a smidge.
AMD: 11111111111111111111 20
Intel: 1111111111 10
20? Really? Lets see it.
Raptors are awesome. Fastest non SCSI drive you can get.
edit: I'd switch from Asus to the Abit AN8 Ultra. I'm partial to Abit and there's no need for SLI on that system. The rest of that system is bangin` though. I'd rock it.
h: Also, if you have external wirefire hdd's, get a 10krpm for the main drive. As clickwir said, there's really no need for SLI; but I've only built with Asus boards
