nearly time for timing belt #2...
Old Jan 17, 2006 | 07:11 PM
AcuraFanatic's Avatar
AcuraFanatic
Originally Posted by b00gers
Wow, so wheel bearings go out at 150k-ish.
That's actually pretty reasonable. I've only had to do one on the Vigor at 150K...trust me you'll know when they go. h:
Old Jan 17, 2006 | 07:12 PM
reno96teg's Avatar
well, my passenger-side did. the driver-side was still fine, i replaced it thinking that was the bad one, but i'm glad i did both anyway.
however, i think what caused it to go bad was when i smacked off a tremendous pothole with 3 other people in the car. two large bubbles developed in my kumho 712s due to that, which is why i later switched to the MXs. aside from that, the 712s actually still had some life. and a bit later, the bearings started to hum, and eventually got loud as hell. like shawn said, you'll know. :chuckles:
so yeah, those were the two "big" things since 90k, the bearings, and the radiator. not bad at all, if you ask me.
edit > almost forgot about the exhaust. three "big" things...
Old Jan 17, 2006 | 07:16 PM
reno96teg's Avatar
looking at that list again, i noticed i didn't switch out my kumhos during the winter of '01-'02. that winter was mild as hell. :chuckles:
Old Jan 18, 2006 | 05:49 AM
egghead's Avatar
egghead
TF Plasti-crack Crew
How was it changing out the wheel bearings...you have to get them pressed in and out right?
Old Jan 18, 2006 | 05:54 AM
the damn wheel bearings on my old car went out like 3 times, it had under 90k on it. even the new ones i bought would shit the bed
Old Jan 18, 2006 | 06:11 AM
eonsx311's Avatar
eonsx311
today is not my birthday.
Originally Posted by AF
When you do the timing belt if you want help I'd be glad to come down, I'm probably not very far away. I haven't done one on a B-series before. :wiggle:
(Done them on other engines though don't worry :chuckles: )
help me too, i keep putting it off and every time i see my tach at 7 i just hope it dosn't snap. 152k and i don't think it has ever been changed... I KNOW I KNOW... im asking for it but i just want to wait till summer to work outside in the daylight cause i dont have very good lighting in the garage i work in... i have drop lighting but it just isnt the same, i cant see shit in low lighting situations...
Old Jan 18, 2006 | 06:20 AM
reno96teg's Avatar
yep. fortunately for me, my fiancee's dad is a diesel mechanic, so he has access to things like a hydraulic press. so we pulled out the knuckle, and brought it by his shop to swap the bearing. there is just no way i could have done it on my own. the press is a must.
i also remember we had a bitch of a time seperating the axle from the knuckle/bearing on the driver side. i'm not sure why, but i'm going to guess 9 or so winters - at that point - probably had something to do with that.
^ under $10 or so at home depot.
Old Jan 18, 2006 | 06:25 AM
egghead's Avatar
egghead
Great, it sounds like I'm going to have a good time. I'll probably do the brakes while I'm down there too.
edit: Where did you buy all that stuff?
Old Jan 18, 2006 | 06:50 AM
reno96teg's Avatar
www.rockauto.com
shipping was more expensive than i would have liked, but altogether is was still signficantly cheaper than going all OEM from acuraautomotiveparts and certainly tons cheaper than getting the parts from the dealer.
Old Jan 18, 2006 | 06:57 AM
meredithf's Avatar
meredithf
...152k and i don't think it has ever been changed... I KNOW I KNOW... im asking for it but i just want to wait till summer to work outside in the daylight cause i dont have very good lighting in the garage i work in...
eh, i wouldnt say youre ASKING for it, you just won't get any sympathy if it does snap
i replaced mine at about 93k and went ~125k before replacing it again a couple months ago. the guy i took it to was still trying to tell me the belt was fine but i went ahead and did it anyway just to be on the safe side.
