Audio question for my friend.
Old Dec 24, 2005 | 11:32 PM
b00gers's Avatar
b00gers
Originally Posted by nhatters
I just noticed you're in Oakland, California, do you know of any good stereo shops in the Bay Area? I'm inbetween Oakland and San Jose, really close to Hayward.
Oh and, for those four speakers and HU, and the Alpine amp, how over powered am I?
Youre not overpowered...with that amp, youre a little bit underpowered. But you are ok. Just set the gains correctly and you should be fine.
Steroshops in the Bay Area to do what?
Old Dec 25, 2005 | 12:06 AM
nhatters's Avatar
nhatters
To do everything. Installation of everything. And a place that has warentees, and won't likely to go out of buisness anytime soon incase something breaks.
Edit: And how badly am I under powered? Also, what would be a good amp for the single type-r sub? Would this be good?
http://iweb.alpine-usa.com/pls/admn/...=140&p_main=10
But it's mono, so would that be bad?
Another edit: If I got these speakers:
http://iweb.alpine-usa.com/pls/admn/...=104&p_main=10
Without and amp, how badly under powered? And with the amp, dangeriously over powered?
Old Dec 25, 2005 | 08:45 AM
b00gers's Avatar
b00gers
Audiomobile
307 11TH St
Oakland, CA 94607-4215
(510) 839-1992
They mostly handle higher end stuff.
Here, if you want to know whether something will be a good match...look at the amp's RMS wattage rating...and the speaker's RMS wattage rating. Those numbers should be similar.
Old Dec 25, 2005 | 12:05 PM
nhatters's Avatar
nhatters
Dealt with them before, or only heard good things?
And if the RMS from the HU and the RMS from the speakers don't match up, find an amp and add the RMS to that plus the HU's RMS and see if that together reaches around the speakers/sub depending on the situation?
It's just, the HU is 18 and the amp is about 14, but I think the speakers required 50, so aren't I really kind under powered? All assuming What I just said was right.
And thanks again!
Old Dec 25, 2005 | 12:55 PM
nhatters's Avatar
nhatters
One last question...
If I got the same HU, and the same Alpine amp, would that be too over powered, or just right? And which would you reccomend? Because most likely I'll just get another amp and sub later, and just live with the HU, speakers, and single amp for a while. HU + amp + Type-R or Type-S?
Old Dec 25, 2005 | 05:58 PM
b00gers's Avatar
b00gers
And thanks again!
Uhh no. You either use the amp inside the headunit OR use the external amp. You dont use both at the same time for the same speaker.
The amp is 14? What amp offers 14 watts?
Old Dec 25, 2005 | 07:46 PM
nhatters's Avatar
nhatters
Sorry I got it mixed up between the RMS stuff.
So, if I got this...
and...
http://iweb.alpine-usa.com/pls/admn/...=120&p_main=10
That would be the perfect match because the amp does 40x4 and those speakers are 40RMS?
But then this HU...
http://iweb.alpine-usa.com/pls/admn/...y=45&p_main=10
Does 50x4, so I wouldn't need the amp if I got the Type-S speakers?
And if I got the sub would a mono amp be okay?
Like this one?
For this sub:
http://iweb.alpine-usa.com/pls/admn/...=150&p_main=10
Or would I need a stronger amp and or stereo one instead of mono?
Thanks again man!
Old Dec 25, 2005 | 09:42 PM
b00gers's Avatar
b00gers
and...
Yes
But then this HU...
No. Most internal amps in headunits are OVERRATED. Dont expect more than 20 or so watts from them.
Like this one?
For this sub:
Thanks again man!
No. That amp is too small. The subwoofer wants 500 watts. Get an amp that is 500 watts RMS. It doesnt matter if the amp is stereo or mono. Being stereo just means that you have the option of controlling 2 separate channels seapartely.
Old Dec 25, 2005 | 10:40 PM
nhatters's Avatar
nhatters
So which would you reccomend?
Type-S with the amp?
or
Type-R with the amp?
Old Dec 26, 2005 | 09:12 AM
nhatters's Avatar
nhatters
Or can you point out a better amp if I just got the HU and the Type-R's?
