Girlfriend's CRV has problems.
Old Oct 7, 2005 | 10:04 PM
Spec R's Avatar
Spec R
Originally Posted by dubcac
The 00LS distributor is different than the 97 CRV/LS distributor because of the OBD2b and OBD2a differences...the plugs are different. Did you try just resetting the ECU? Whenever I get a misfire code, it will idle like shit...then I reset the ECU, and it runs fine...just an intermittent thing. Do you have spark? Test the wires for resistance, or throw in a new set. If you can get your hands on a spare distributor to try for free, definitely do it. You may have a weak coil that is on its way out. If you were in norcal, I'd let you try one of my distributors...I have 2 spares. h:
yeah i wish i saw your post before i went and did it. plugs are way different. if i had my hands on a multimeter, it would be so much easier, but i dont so i cant test shit. thanks though...
i've worked on it all day, new fuel filter, new plugs, tried using 96 LS injectors, etc etc.
DB Squad
Integra Forum Moderator
Old Oct 8, 2005 | 05:08 AM
VPUPPY's Avatar
VPUPPY
what about your plug wires? how old are they? i have had those ground out on multiple cars before causng a misfire.
