Need some car purchasing help
Originally Posted by ED9man
Don't RSX's have chronic understeer issues? If you are going with an Integra, get the DC2, factory oversteer, and it is so much racier and more original than a Type-S.
It's a front wheel drive car. It will always understeer when power is applied.
It just so happens that an ITR has a thick rear sway bar that keeps it neutral in turns up until the point you put too much power to the front wheels at which point the fronts will break loose.
The regular ole DC Integra, not from the factory. Both it and the RSX can have their suspensions tuned to hang the tail out to a certain degree.
The advantage is that fanboys can complain about how the RSX sucks because it has struts so their old busted Integra or Civic or whatever is far superior.
im getting tired of people saying macpherson's suck on the rsx/new si just because its new to the honda world, whereas so many other manufacturers with awesome cars use the same setup. i think in general everyone is just so used to the doulbe wishbone design and the ease to make them very neutral and easy handling they don't give them a chance.
back on topic i think a used wrx would be a good buy and you could get it for that price as well. itr will be to much a hassle to find and your going to get a older car that is dope but dont turn into a type-R lover till you drive it and decide if its worth the hype.
honestly you shouldve just kep the gsr
I wasn't saying they suck... :dunno:
