Honda vs. Toyota's Variable Valve Timing
Old Sep 24, 2004 | 03:22 PM
Frankie Dirtbag's Avatar
Frankie Dirtbag
The White Man's Burden
did BMW develop the first vtec-like engine?
Old Sep 24, 2004 | 03:26 PM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Originally Posted by Kestrel
Actually IIRC either the GSR or the Type-R have some sort of variable intake manifold.
My Integra LS has dual air filters, a small one on top that has a short pipe and then a big on that goes down into the wheel well.
Most mechanics and car people round here have no idea what I'm refering to though.
clickwir's Avatar
clickwir
I know Honda's first one was the NSX... they were one of the first if not the first with VTEC.
Old Sep 25, 2004 | 08:55 AM
catatonic's Avatar
catatonic
(´Д`)
VANOS?
Old Sep 25, 2004 | 09:42 AM
Cosmo M3's Avatar
Cosmo M3
Lurker
Originally Posted by catatonic
VANOS?
:werd:
Old Sep 25, 2004 | 09:43 AM
qtiger's Avatar
qtiger
Originally Posted by bluetwo
then who is it that varies intake pressure?
am i retarded?
Anyone with a throttle body varies intake pressure.
Old Sep 25, 2004 | 10:11 AM
dubcac's Avatar
dubcac
I
The GSR and newer H22 preludes have dual runner intake manifolds. They promote better torque in the lower-mid range, and then once you reach a certain rpm (5500 in the gsr) the butterflies route the airflow to shorter intake manifold runners for maximum all out power.
:ugh:
Old Sep 25, 2004 | 10:39 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
actually, I thought Alfa Romeo had the first variable vtec like system..
Old Sep 25, 2004 | 10:46 AM
mayonaise's Avatar
mayonaise
http://auto.howstuffworks.com/question229.htm
http://www.mr2sc.com/websites/articles/vvt.htm
honda made the first production car to have variable valve timing, the 1991 NSX. but i'm pretty sure companies (not just honda) had been using it for years in racing. no idea who invented the concept
edit: VTEC and VVTi are a little different. VTEC = variable valve timing and lift electronic control. the links above should explain it. VVTi doesn't have lift. VVTLi probably does, i'm not sure. variable valve timing is pretty commonplace now, but for the past thirteen years it was almost uniquely honda.
Old Sep 25, 2004 | 10:48 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
ah alright, I was pretty sure that Alfa was one of the firsts atleast, but it wasnt in 91, way earlier.
